6x6?
Posted: Tue Aug 23, 2016 8:41 pm
by VinceAtReal4x4s
Hope they took the advice.
Re: 6x6?
Posted: Wed Aug 24, 2016 6:36 am
by stiffler4444
WHOA! Step far far away from the welder. Judging from what I can see, The only true "welder" in this equation is the machine itself......
Re: 6x6?
Posted: Wed Aug 24, 2016 7:50 am
I guess some folks just prefer 6 wheels?
What immediately springs to mind was a blue Ford Taurus wagon I saw up at Road America several years back with tandem axles on the rear. The two rear axles meant they needed to sacrifice the rear doors, so it was only a two-door. That one looked pretty cool, IMHO.
Re: 6x6?
Posted: Wed Aug 24, 2016 10:12 am
I met a guy in the late 90's who had added three trailer axles (unpowered) behind the rear axle of a small pickup, cut the bed and made a four axle fender opening. They actually did a very neat job of it - looked very cool. You could put a 16' board in the bed and close the tailgate! It had no roof or rear wall to the cab, just an open air vehicle. I asked him what the biggest drawback was and he said "transitioning from level to a steep uphill driveway - it has a tendency to lift the drive axle off the ground!". With only one drive axle, I guess this would be called a "2x10".
Re: 6x6?
Posted: Wed Aug 24, 2016 11:27 am
by Haf-e
Much better with front wheel drive...
Re: 6x6?
Posted: Wed Aug 24, 2016 12:45 pm
by Heinkeljb
I want one of those to put the Haf on, except I don't want it so long!
Anything similar, currently produced?
John
Re: 6x6?
Posted: Wed Aug 24, 2016 1:03 pm
by Haf-e
I just use my Sprinter van - my hafi fits in the back with seating for five still in the front... wheels fit between the wheel wells also - I have a small electric winch with a wireless remote to pull it in - but I used to drive it into it...
Re: 6x6?
Posted: Wed Aug 24, 2016 3:03 pm
You just don't have enough Hafies yet!
Re: 6x6?
Posted: Thu Aug 25, 2016 1:28 am
by Heinkeljb
Can't justify a Sprinter van big enough to put a LWB in. Plus I don't have anywhere big enough to store something that long - one of the reasons I got a Haf rather than anything else like a Pinz or a C303....
It would have to double up as an everyday car.
John
Re: 6x6?
Posted: Thu Aug 25, 2016 12:55 pm
by audiocontr
Re: 6x6?
Posted: Thu Aug 25, 2016 2:04 pm
by Heinkeljb
The mini looks interesting, wonder if you can make one with just a single rear wheel? The Merc is just to big!
I had thought of something along the lines of a wide vehicle so you get a couple of seats on either side of the Haflinger when it was loaded on from the rear vehicle. That way you can take 4 people as well when you travel with or without the Haf.
John
Re: 6x6?
Posted: Thu Aug 25, 2016 2:19 pm
The Mog would be basically the same speed as just driving the Haflinger
Re: 6x6?
Posted: Thu Aug 25, 2016 3:25 pm
by audiocontr
Mini suspensions are quite weak. It would need to be completely custom and a hefty axle =)
Sourced from a rotted out trailer maybe?
Re: 6x6?
Posted: Thu Sep 15, 2016 2:52 am
by Dreadnought
I remember a lot of 6 wheeled minis back in the day.......minis have a rear subframe so you just add a second subframe and extend your body......there were stronger/lower/taller cones available for rallying and that kind of thing.
