Aftermarket distributor clamp
Posted: Sat Jan 14, 2017 1:34 pm
by pinzinator
Has anyone ever found an aftermarket distributor clamp that will work OK on the Pinzgauer? There's nothing wrong with the OEM part, I am looking for something that clamps the shaft section outside the block, vs clamping on the diameter that goes into the block, which is a few millimeters narrower.
Re: Aftermarket distributor clamp
Posted: Sat Jan 21, 2017 7:52 am
by pinzinator
I have found one that works, the opening for the distributor has to be reamed a millimeter. Other than that it fits perfect and makes adjusting the timing easy.
