Rear Door Lock Plate 28-25-24
DeStoriesair
Post by DeStoriesair »
Has anyone removed the Rear Door Lock Plate (Group 28-25-24) for the tailgate latch?
I am needing to get a nut on a bolt that passes thru the top of the door frame for a aft closeout panel I made and it is not just simply sliding off after I remove the screws.
I did not find anything in the maintenance manual and the IPC does not give much for removal.
Can it be removed without the interior components falling out?
Pinzgauer 710M
http://www.swpinz.com
Facebook: Southwest Pinzgauer
whitesik
Re: Rear Door Lock Plate 28-25-24
Post by whitesik »
The plate will come off in one piece with the latch 28-25-05 attached to it assuming the handle and locking bolt knob and handle are removed to allow passage through the rear panel.
75 Swiss 710K
W9YG
