Stuck in 4wd
Stuck in 4wd
Hello, my friend have a pinzgauer and it is stuck in 4wd. He engage it and forget to disengaget it when pinz sit in the garage for a month. Now the lever wont go back. Any technic used or any suggestions what to do?
Re: Stuck in 4wd
the lever always should go back in diseng. pos.
but the light doesnt go off when the muffling is stuck.
when stuck and trying to reengage the lever its not possible to pull it down again cause due hydraulic lock in the system.
id try at first some driving on gravel with left right curves and change of momentum to loosen it up .
normaly it should fix.
otherwise manual fixing is an option with removing the cylinder and carefuly tapping it back
