E-Brake handle plastic coating
Posted: Fri Nov 23, 2018 7:41 pm
by mm58
All of the hard plastic coating on the E-brake handle grip had gotten brittle and broken off.
It is just bare metal now.
Anyone know of a way to re-apply this coating? I don't think "Plasti-Dip" will do the trick (too soft)
Re: E-Brake handle plastic coating
Posted: Fri Nov 23, 2018 11:55 pm
by rmel
Black 1/2” heat shrink tubing with a 1/2” heat shrink end cap.
Posted: Sat Nov 24, 2018 12:19 am
by mm58
Hmmm, that seems like a pretty good idea. I might have to give that a try. Thanks Ron!
Posted: Sat Nov 24, 2018 10:27 am
by rmel
If the old modeled on plastic is still intact but cracked up and disintegrating,
might be good to patch it up and leave it on then use shrink tubing over it
to retain the bits in place. The handle tappers quite a bit, generally, shrink
material is 2:1 reduction in diameter. That just might work but may be loose
at the tip of the handle, thus a smaller diameter shrink end cap would help.
There is a 3:1 material on the market, it's more expensive and sourcing might
have some challenges.
Posted: Sat Nov 24, 2018 3:17 pm
by mm58
3/4" 2:1 shrink tube. The bends were just too tight to get the tubing to lay out nice and smooth.
You can see how it bunched up with wrinkles and overlaps.
Oh well...back to square one :DD
Posted: Sat Nov 24, 2018 6:41 pm
by 4x4Pinz
all my ebrake handles appeared to be powder coating or an epoxy coating. If I were to refresh mine I would pursue those options.
Posted: Sat Nov 24, 2018 8:17 pm
by mm58
Thanks Mike. Are your powder coat/epoxy ones OEM?
Mine was like a very thin hard plastic - like a hard boiled eggshell.
Posted: Sat Nov 24, 2018 8:24 pm
by 4x4Pinz
OEM. Some have redone theirs in Red, not sure what product they used. I have a few knicks in the one in my 712 and yes it is rather thick application.
Posted: Sat Nov 24, 2018 8:42 pm
by 4x4Pinz
https://www.tapplastics.com/product/fib ... oxy_resins I would think one of these products would match up with existing and work very well if not better. maybe an email to customer service for best option.
Posted: Mon Nov 26, 2018 1:37 pm
I repaired my Haflinger steering wheel with some epoxy, sanded and then painted - looks like new.
For the e-brake I want to redo mine at some point too - my idea was epoxy (perhaps even just JB Weld), sand and then either 2k paint or may just plasti-dip it
Posted: Mon Nov 26, 2018 1:38 pm
weird double post - can't delete
Posted: Tue Nov 27, 2018 5:08 pm
by mm58
As much as I didn't think Plasti-Dip would work well, forum member "bumber"
encouraged me to give it a try.
Because the retaining pin is frozen (I can't even drill or drift it out),
I had to apply it in-situ with a small acid brush.
Pic is after two applications letting it dry completely in between.
I'm really surprised how evenly it flowed out, and it seems to be pretty tough.
It has a nice soft rubbery feel, but not so that it feels like it's going to easily peel off.
Posted: Tue Nov 27, 2018 7:18 pm
by rmel
Wow, that came out really nice -- and done in place to boot!
Gotta bookmark this page :wink:
Posted: Wed Nov 28, 2018 12:26 pm
Nice!
