Valve Adjustment After Pinz SSI
Buzz
Post by Buzz »
Getting ready to do a full tune-up and was wondering how you guys find TDC after you have the SSI installed. I always used the distributor head before I added the SSI. Can I use the LED light on the module? Suggestions appreciated. - Buzz
1974 Pinzgauer 710M
1990 Puch G Wagon 230 GE
Re: Valve Adjustment After Pinz SSI
Yes, the LED would work. I got lazy and just cranked by hand until
the valve rockers were loose :wink:
Hotzenplotz
Austria
Post by Hotzenplotz »
I take off all cylinder head covers and crank the engine by hand.
when cylinder 1 closes exhaust and opens intake valve cylinder 4 is in ignition position with both valves closed. cyl 4 can be adjusted now.
one turn of the crankshaft later cyl 1 is in ignition and you can adjust cyl 4.
the same applies to cyl 2 and 3
your ignition method is irrelevant for that method, you can adjust diesel engines with the same method.
additionally there is a mark on the wheel for the v-belt indicating top position on cylinder one
Albert
Pretty much my approach as well. Though I also add a mark at 180
from TDC to rotate in #2 in position after setting #1. Then another
180 to rotate in #4, finally 180 more for #3.
It was easier to do this with the distributor cap off to see when the
rotor would be on #1 at TDC.
With the Pinz SSI that's not as obvious unless you do this with IGN
on and observe the LED go on indicating #1 is in position. Probably
not a bad idea to do just that to unambiguously identify #1 (versus #4
when at TDC) while also checking timing.
Buzz
Post by Buzz »
Thank you gentlemen! This is very helpful and I will get after it in the next day or two I’ll let you know how things go. – Buzz
1974 Pinzgauer 710M
