Truck won't turn off?
Posted: Fri Jun 25, 2021 9:39 pm
ok, bit of an oddball issue here I’m struggling to wrap my head around. My truck won’t turn off
as soon as I turn the battery switch on my fuel solenoids click and have power, no matter the ignition switch position. The problem is the PinzSSI takes its power from those same solenoids. Once running turning the ignition key or the battery switch does not cut power to the solenoids, so the PinzSSI doesn’t know to turn off and the engine continues to run. Pulling the included fuse for the PinzSSI in the battery box is my only means of turning the engine off right now
I thought it was an ignition switch issue, so I swapped it for a new one from EI. This did not solve the issue. I tried to isolate the issue, disconnecting everything else remotely connected to the solenoids electrically, including: PinzSSI, starter button, headlight switch, horn, blower switch and motor. One at a time I disconnected wires from the ignition switch until I no longer heard the solenoids click when I turned the battery switch.
Somehow the black wire from the ignition switch to breaker #10 that should be the solenoids power source did not have any affect. The middle and left red wire pictured are the 2 wires I can pull to stop power going to the solenoids. +24V supply is coming through the center red, the rightmost goes to the headlight switch, and I have no idea where the left most red wire goes. The wiring diagram clearly shows only 2
#10 breaker is clearly wired as per the diagram, so that mystery red wire isn’t going there
this is exactly how the previous ignition switch was wired up, and continuing to run is a recent problem. At first it would hesitate to turn off with the key, but now it does not turn off at all. My only guess is there’s a short somewhere in the connectors (33). I’ll need to dive in deeper with a multimeter tomorrow, but I’m open to and incredibly appreciative of any and all help understanding what the heck is going on and where to look to solve this puzzle
it’s a swiss 712 with an ambulance body
