Tailgate sag
Posted: Mon Jan 06, 2025 11:11 pm
by rollingpinz
Hello
I’ve noticed that my tailgate sags a bit, but I don’t really see any adjustment on the hinges. Has anyone dealt with this?
Re: Tailgate sag
Posted: Fri Jan 24, 2025 2:55 am
by David Dunn
It's been 22 years since I had a gas pinz, but look on the door half of the hinge, there may be an adjustment there. That's where it is on the front doors.
Also, you may take the door open it a couple inches and lift up and down on the lock end of the door and see if the door rocks. You could have worn hinge pins and hinge bushings.
Re: Tailgate sag
Posted: Thu Jan 30, 2025 6:02 pm
by rollingpinz
The screws on the body side of the hinge were very difficult to remove. Part of the problem was they wouldn’t thread all the way in. I don’t have a tap that big so I cut some edges into a bolt and cleared the threads. This locked that end of the hinge down. An improvement for sure.
The hinges are a bit loose though. I can’t seem to find anything about hinge bushings and I didn’t see any kind of adjustment. Maybe I missed it.
The project continues
Re: Tailgate sag
Posted: Thu Jan 30, 2025 11:44 pm
by David Dunn
The adjustments would be on the door side, not the body side.
