Fan/pulley nut
Posted: Tue Mar 25, 2025 3:52 pm
by rollingpinz
Is it ok to use an impact to remove the fan/pulley nut?
I have 3 to choose from to accommodate torque levels. Pneumatic 1/2”, dewalt brushless 1/2”, and dewalt brushless driver.
Also, is there a torque setting for putting it back on?
Re: Fan/pulley nut
Posted: Tue Mar 25, 2025 5:41 pm
by rmel
I wouldn't use one, it's all unique hardware no margin if you mess it up.
Use the special fan locking pliers and a breaker bar. Torque = 67 Nm.
Re: Fan/pulley nut
Posted: Tue Mar 25, 2025 6:09 pm
by rollingpinz
Sounds good. Thanks.
The reason I ask is because my front main seal is weeping a bit.
So, removing the nut that holds the bottom pulley, same question: impact?
What about putting the nut back on?
Re: Fan/pulley nut
Posted: Tue Mar 25, 2025 6:36 pm
by rmel
Ya, did that front main seal repair before. Ya, impact OK for that bad boy.
Getting the dang seal out can be a PITA at times.
Re: Fan/pulley nut
Posted: Tue Mar 25, 2025 6:56 pm
by rollingpinz
Thanks. Any special tools or techniques to drive seal in?
Re: Fan/pulley nut
Posted: Thu Mar 27, 2025 1:25 pm
by ChickenPinz
I've done the rear, but not the front.
Make sure everything is spotless before installation and there are no burrs anywhere and the shaft is undamaged. Make sure to lubricate the seal.
For the rear seal, I used a piece of ABS pipe fitting that was a nice diameter match, and a board over that, and gently tapped into place. Can't speak to the front, but maybe something similar will work.
Re: Fan/pulley nut
Posted: Thu Mar 27, 2025 3:14 pm
by Hugues
I changed that seal.
I broke the pulley while trying to hold it in place to remove the nut. Cast iron is fragile.
I jammed a wrench on the nut and spinned the engine a second, it worked. Be sure to disconnect the distributor so the engine does not actually starts. Discussed here :
https://pinzi-forum.de/viewtopic.php?t= ... c14cc31ced
Putting the pulley back in was a pain, I had to tap it in as it did not slide in, but there is a keyway on it so you need to align it very well first, so you don't push the key. Took me a while.
I built a tool to pull the pulley out, discussed here :
Re: Fan/pulley nut
Posted: Thu Mar 27, 2025 5:17 pm
by Puty
rmel wrote: Tue Mar 25, 2025 5:41 pm
67NM in case you have a M14 Nut, 150NM if you have the M16
