Help Removing Flywheel Bolts
Posted: Sun May 18, 2025 8:51 pm
by mm58
I need to replace the ring gear on my flywheel but cannot seem to even
budge the six bolts holding it on. What's the trick?
I've even put a pneumatic impact wrench to them and no joy.
Any help appreciated
Re: Help Removing Flywheel Bolts
Posted: Mon May 19, 2025 8:10 am
by rmel
HEAT is your friend.
Someone buttered up the bolts with Loctite.
Posted: Mon May 19, 2025 10:34 am
by ChickenPinz
mm58 wrote: Sun May 18, 2025 8:51 pm I need to replace the ring gear on my flywheel but cannot seem to even
When I first did mine, my old-school pneumatic impact wrench was unable to break them free, and I had to borrow a stronger one and use a larger/shorter air hose. They should be on with thread-locker so they'll be tough. Heat (torch or induction) will help, but I can also get mine off cold with a Dewalt DCF899HB which claims 700/1200lb of torque.
Posted: Tue May 20, 2025 4:00 pm
by mm58
Thanks for the info guys!
I put a two foot breaker bar on those bolts and was able to crack them free
fairly easily.
Fun stuff...!
Posted: Sun May 25, 2025 12:41 pm
by Stumbler
Just be sure when you replace them you use NEW bolts. Those are supposedly 1-time use bolts. When you tighten them you tighten them to the torque in the book, and then you go another 1/4 turn to stretch the bolt. At least, that was my understanding.
Posted: Sun May 25, 2025 8:36 pm
by ChickenPinz
You turn them 60-degrees past contact, not 90-degrees.
IMHO, the bolts are fine to reuse so long as you know they've never been over-torqued. If the bolts haven't haven't been taken past their elastic zone, I don't see why they'd be unfit for reuse.
Posted: Fri May 30, 2025 9:22 pm
by mm58
I did re-use my OEM bolts.
And yes, pre-torque to 20Nm, then 60 degrees past that
which equates to one facet of the hex head.
