Its all about timing...
Posted: Mon May 15, 2006 9:58 pm
by NC_Mog
What is the most advance that a Pinz engine can run on regular unleaded gas? I thought I had read somewhere that the Pinz engine was sensitive to timing.
The reason I ask is that after installing a Pertronix module, I checked the timing. It was slightly advanced, so I adjusted the distributor back. I was only able to get it to around 5mm advanced with a warm engine (I believe the stock spec is 3mm advance with a warm engine). The engine rpm at idle correspondingly went up slightly. I'm trying to decide if I leave the timing at 5mm and adjust the carbs to give a lower idle speed or if I adjust the distributor more. The reason I didn't adjust the dizzy back more is that it seemed to be physically blocked from turning any more...I'm thinking it may have to be adjusted one tooth over.
Posted: Tue May 16, 2006 11:14 pm
by Lightningpinz
Max advance here at 6000 ft I go about 7 degrees max.
Remember on the dizzy there is not a gear lilke a Chevy or Ford. There is a flat with an offset drive spline. If you try hard enough you can get it 180 out.
