On the road again
Posted: Fri Oct 06, 2006 2:47 am
I finally had the front LH hub repaired.
The obvious failure was an oil leak, which ended up in both inner and outer ball bearings needing replacement (besides the oil seal of course).
The bill I paid was terrible ...
- 8 hours labour (all bolts were rusty in my ex-Swedish Pinz, and extracting the gear wasn't an easy affair too)
- 210 euros (about 250 USD) for parts.
Luckily, the RH hub looks recently overhauled and has no play.
The most expensive part was, by far, the outer ball bearing. It has quite an an odd size and I my mechanic said he had to order it to Magna-Steyr.
Does anybody confirm? Or, is there an alternate source for that bearing?
Cheers from Italy,
Ugo
1977 710K
1990 716K
Cheers from Italy,
Ugo
1977 710K
1990 716K
