Wooden Side Rails
Posted: Sun Feb 11, 2007 6:07 pm
by SAM. C.
Hi All
Has anyone got any technical drawings for the wooden side rails for a 710M?
Any format will do.
Sam
Posted: Mon Feb 12, 2007 12:22 am
by Twebba
If you look in the Yahoo Groups website, there are 2 sources:
The first is in the Photos section titled "Side rubrails" - posted by Hawkwind5USA. This drawing does not account for the 1/4 inch straight part at the base. (Compare these 2, you'll see what I mean)
http://tinyurl.com/39otsb
The second is in the Files section labeled "Pinz Wood Rail Dimensions.jpg" - posted by Matt Shepardson.
http://tinyurl.com/3a6g9s
Your best bet is to work from the specs in both to get the overall-picture of what to cut (with a little fudge factor). Trust me, no one's going to test you on this.
In order to view the links, it's best if you're already logged into the Yahoo Groups site.
- Good luck!
Posted: Mon Feb 12, 2007 5:32 am
by Scooter
I thought that the hole positions were not exact and more done on the fly when installed on the truck. I would check the locations before putting in any holes in the new part.
Scooter
Posted: Mon Feb 12, 2007 9:25 am
by russ
I believe they actually used a jig at the factory to keep them all identical. Spacing is the same between all vehicles I've seen. I have made them for 710Ks and Ms and it's pretty easy to do once you have the process down. I've used Trex and another brand of manufactured wood that Home Depot had.
Posted: Mon Feb 12, 2007 3:26 pm
by todds112
russ wrote:I believe they actually used a jig at the factory to keep them all identical. Spacing is the same between all vehicles I've seen. I have made them for 710Ks and Ms and it's pretty easy to do once you have the process down. I've used Trex and another brand of manufactured wood that Home Depot had.
That's an awesome idea. I was thinking about some kind of heavy solid rubber (even if the shape isn't exactly right. But using the Trex stuff would last foreever too.
Posted: Mon Feb 12, 2007 4:54 pm
by russ
Trex and the other manufactured wood products have pretty good compressibility. They have no structural strength but don't need it for a rub rail. Big thing is they don't rot. One of my original rails was growing mushrooms!
rub rail fun...
Posted: Mon Feb 12, 2007 7:52 pm
by dougj
its actually a good idea to take them off from time to time, and inspect the metal. the rub rails have a tendency to well... rub... against the base metal, and to trap moisture. in short. a common rust area is under the rub rail.
rub rails
Posted: Mon Feb 12, 2007 8:14 pm
by krick3tt
After crushing mine I replaced them with 1 inch by 2 inch steel chanel. Held them off the body with 1/8'' alum washers. I will use them later to add a rack and use the rails as a base for the supports. It is not 'stock' but it seems to work. I thought about Trex, I have seen it done and they look good.
Morris
Posted: Tue Feb 13, 2007 6:31 pm
by Hawkeye Pinz
When I bought my 710 M about a year ago the rails were pretty rotten. So I took one off the truck, used it as a template and made a new set out of Trex. They look pretty good and shoud last for quite awhile.
Posted: Tue Feb 13, 2007 9:56 pm
by springhill
I bought the rubber rails from CWR and have been very happy with the result. I don't remember the cost, but the hardware is first rate and the rails will absorb an impact better than wood.
