Weird LED symptom
Posted: Wed May 23, 2007 9:22 pm
by todds112
I got one side of my LED upgrade done. Keeping it simple using a single Stop, Turn, Brake light. I have read that I might need an electronic flasher unit, others have not needed it. Well I tested it and found that I was not getting the click-click inside and the dash indicator was not flashing. When I stepped out, the lights were flashing normally (front and rear). Guess I'll need the flasher after all.
Weird. :roll:
Posted: Thu May 24, 2007 8:46 pm
by todds112
Got the Signal-Stat ecltronic flasher from NAPA. Works great. Had to bend the rear braces in just a bit to clear the lights, but got everything installed. Do need to get one new reflector that I broke accidentally. :roll:
Posted: Thu May 24, 2007 9:25 pm
by milesdzyn
You might find one that matches here twards the bottom of page:
http://www.saturnsurplus.com/lights/lights.htm
Lots of 24v lights, Reflectors and Marker lights. I think they also have the original replacement headlight bulb for the Pinz "Hagglunds Replacement Bulb" didn't say if it was 24v or not though.
Miles
Posted: Fri May 25, 2007 3:26 pm
by todds112
Thanks Miles, I found some on Ebay identical to that. Bought 2 so they will be the same.
