Dry bushing in short shaft of witches hat
Posted: Sat Jun 23, 2007 1:05 am
While I knew the fork was broken in the witches hat off of the Hi-Low gear box, I found that the dry bushing located in the end of the short shaft was worn, almost completely away. The repair manual doesn't say anything about lubrication and since its called a dry bearing I don't know if any is necessary. But since it is spinning metal to metal is there any kind of lubricant that will stay put and not foul the gear oil inside the witches hat?
Also how often should this bearing be wearing out?
Miles
Miles
