Battery chargers
Posted: Fri Dec 21, 2007 10:51 pm
by M Wehrman
I am thru with splitting the batteries to charge during non use. :x 24v chargers seem over-priced :shock: ,other options?
Mark
Battery Charger 24 volt
Posted: Sat Dec 22, 2007 4:33 pm
by Thomas-E
I found and purchased one from Harbor Freight
Model # 91325-0VGA
It is a dual 12/24 switchable unit, I'm happy with it and the current price is $49.99.
It is occasionally on sale in their catalog, about $30.00 :D
Thomas E.
712m
Sonora, CA
Posted: Sat Dec 22, 2007 7:05 pm
by M Wehrman
Thanks,spent a lot of time there...didn't think to check. :oops:
Mark
Posted: Sun Dec 23, 2007 5:30 pm
by ms1223
My batteries would run down in a couple of weeks when sitting after I installed the battery equalizer. This solved the problem. A Soneil 24v 1.5 amp (electronic maintainer) battery charger. I leave it attached to the battery handles in the battery compartment. Cord tucks in between the two batteries.
Swifty in Illinois
http://www.batterystuff.com/battery-cha ... t/0-4amps/
Posted: Mon Dec 24, 2007 8:04 am
by Foz
I use a 20/12 amp battery balancer - which is wried to a 12v to a marine type fuse panel like this:
http://www.boatersworld.com/product/196 ... 3Bcipanels
I added switches to lift the 24v and 12v connections to the balancer so I can turn off the balancer and the entire 12v panel - which brings the quiescent drain on the battery bank down to near zero when the truck is parked.
