napa auto reference numbers
Posted: Thu Jan 10, 2008 2:24 pm
by TurboJim
I spoke w my local napa today for a voltage regu;ator and a flasher they dont show a cross reference for the bussman flasher or the voltage regulator and also whats good for battery replacement
Posted: Thu Jan 10, 2008 4:20 pm
by AK NIMROD
TRIED NAPA ...GAVE UP AND ORDERED ONLINE
I ORDERED VOLTAGE REG FROM EXPED. IMPORTS , ARRIVED HERE IN ALASKA YESTERDAY TOOK 4 DAYS.
HAVE TO REPLACE CHAINS FOR CHAIN DRIVE ON MY GATOR SO I CAN FINISH PLOWING THE 12 INCHES OF SNOW WE GOT THEN THE PINZ WILL GET NEW VOLTAGE REGULATOR.
Posted: Thu Jan 10, 2008 4:37 pm
NAPA equivalent of flasher module is #EG23.
EI and SAV have the regulator. SAV # is SAV2606 @ 31.95. EI # is EIC2606 @ 29.00.
Posted: Fri Jan 11, 2008 7:30 am
by TurboJim
Sav and ei are backorder on regulators this number is from another post but i didnt have any luck finding it
Alternative parts - Voltage Regulator 28V-30A
Wilson 62-15-6647 (24V) At some Champion Auto and Napa
V.R.
Posted: Fri Jan 11, 2008 11:32 am
by Thomas-E
You need to check the other posts, this was just discussed two topics down from this one.
Try...
Superior Distribution Center Inc.
P.O. Box 2909
1142 South First Street
Turlock, CA 95381
Toll free: 1-800-457-1728
Fax: 209-667-8208
Order- Renard #35-9128 (24V)
(Exact Replacement for Wilson 62-15-6647)
This is where I found one.
Tom E.
712M
Sonora, CA
Re: V.R.
Posted: Fri Jan 11, 2008 2:45 pm
by TurboJim
in respect for others i didnt want to steel the post from someone else but i did check all those part numbers with napa and they do not list them also superior doesnt stock that number either ...but i did say that earlier
Thomas-E wrote:You need to check the other posts, this was just discussed two topics down from this one.
Try...
P.O. Box 2909
Turlock, CA 95381
Fax: 209-667-8208
Tom E.
712M
Sonora, CA
Posted: Fri Jan 11, 2008 3:55 pm
by AK NIMROD
turbojim- where are you located? if you are needing this up and running soon i might be able to help.
i must have gotten the last 2 from EI..
....so i have a spare.
i could send it to you but shipping will be double since i paid it to get it to Alaska.
Shipping to most places in "America" takes about 3-4 days priority mail.
Voltage Regulator Source
Posted: Fri Jan 11, 2008 8:02 pm
by Thomas-E
I don't know if they are in stock, but a search found another potential supplier....You might try them,
www.rcpcanada.com
RCP PART NUMBER: VRB199-4
DESCRIPTION: REGULATOR, BOSCH 24V
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
FEATURES/NOTES: 'B' Circuit
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
64800005 - MAGNETI MARELLI
6480005 - MAGNETI MARELLI
505-057 - MOTOROLA
9RH8091 - MOTOROLA
0192033003 - ROBERT BOSCH
>0192033005 - ROBERT BOSCH<
11548806 - MERCEDES-BENZ
21540206 - MERCEDES-BENZ
350477102 - MERCEDES-BENZ
13335 - Old RCP Number
Thomas E.
712M
Sonora, CA
Posted: Sat Jan 12, 2008 10:01 am
by TurboJim
AK NIMROD wrote:turbojim- where are you located? if you are needing this up and running soon i might be able to help.
Thanks nimrod I got hold of willie and hes gonna send me a used one for now he said should be febuary for new ones
Re: Voltage Regulator Source
Posted: Sat Jan 12, 2008 10:27 am
by TurboJim
Thomas-E wrote:I don't know if they are in stock, but a search found another potential supplier....You might try them,
www.rcpcanada.com
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
505-057 - MOTOROLA
9RH8091 - MOTOROLA
Thomas E.
712M
Sonora, CA
Thanks Thomas are all these part numbers for a direct replacement regulator
