Water fording: snorkels and more...
Posted: Mon May 26, 2008 5:20 am
Hi all,
At some point I might take my Pinz through a mountain stream that I have crossed numerous times -mostly as passenger- in snorkel-equipped LR Defenders. Problem is, depending on snow cover and weather, the water level can be below 2 feet in the morning and above 3 feet in the afternoon... After having searched this forum and the internet about water fording in general, and more specifically for the Pinz', I still have a few questions:
1) There are a few threads on this forum about snorkels. I know that water entering the engine is as bad as it gets, and a device that makes sure it does not happen is a must when going into seriously deep water, but looking at my 710 I could not help but notice that the stock air intake is already quite high, just below the engine access hatch. Was another element considered by those installing a snorkel, like the risk of having the fan spray water into the air intake? Should I install a snorkel, it would be a "flexible-tube-trough-the-front-grille" temporary one, but I wonder until what actual depth I can safely do without one.
2) The height of the stock air intake made me hint at the fact that the factory-given fording capacity of 70cm/27.6in is affected by the need to protect the electrical components of the truck, too... What can / should be done to protect the ignition and other electrical components (alternator, even batteries) from water?
3) I've seen that adding "axle breather" tubes or "wading plugs" is common for Land Rover owners... is there anything similar for the Pinzgauer that can be added, or simply that has to be kept in mind regarding water fording and transmission components?
Sorry for the longish post and thanks in advance for your input!
Jan
Jan
