Driveshaft u-joint
Posted: Tue Jul 08, 2008 11:35 am
by swift1223
Does anyone have a NAPA or Aftermarket number for drive shaft u-joints? (SHAFT OFF THE TRANS)
Posted: Tue Jul 08, 2008 2:06 pm
by Jim LaGuardia
SAV has an aftermarket one in stock #SAV1000, they are $39 and change, or the original replacement(my preference) for $125 :wink:
The factory ones are serviceable while the aftermarket ones are not(no lube fitting)
Posted: Tue Jul 08, 2008 3:02 pm
by ms1223
Thanks Jim, I'm suprised that the replacement is not an off the shelf part. The one I removed (no zerks) had USA stamped on it.
Posted: Tue Jul 08, 2008 4:07 pm
by mjnims
I have had one built by a local driveline shop here. The flanges are off of a jeep cherokee and the rest of the shaft is just normal material. The ujoints are now readily available. An initial cost layout but very serviceable/replaceable as needed. They also were able to give me a guarantee on the shaft. Still one of those less expensive fixes to go through one of the pinz dealers.
Posted: Tue Jul 08, 2008 5:13 pm
by rubicon4wheeler
mjnims wrote:I have had one built by a local driveline shop here. The flanges are off of a jeep cherokee and the rest of the shaft is just normal material. The ujoints are now readily available. An initial cost layout but very serviceable/replaceable as needed. They also were able to give me a guarantee on the shaft. Still one of those less expensive fixes to go through one of the pinz dealers.
I thought the Cherokee's driveshaft just had yokes with U-joint straps, rather than a flange like a Pinz or a Toyota or a Suzuki. :?: :?: :?:
I will be having to get a custom driveshaft made to allow me to fit a Trail Tough "Rock Block" gear reduction box inline between the transmission and transfer case (along the lines of the Klune, but without the problems they cause) but I need to source or make a Pinz-to-Suzuki flange to make this work. If the Cherokee uses flanges that would work, then that will make my life several orders of magnitude easier! :D
From what specific Cherokee model do we source these Pinz-adaptable driveshaft flanges???
Posted: Tue Jul 08, 2008 5:21 pm
by mjnims
I will have to stop by the driveshaft shop and check with them. They did not even skip a beat when I laid the old shaft on the counter and asked if they could build me a new one, just went over to the shelf and pulled the parts like it was an everyday thing.
Posted: Tue Jul 08, 2008 5:24 pm
by rubicon4wheeler
Yeah, building a shaft is easy. Even making a custom yoke is easy.
But making a flange is not.
Please keep us updated with any info you can get! Many, many thanks!
Posted: Wed Aug 13, 2008 7:06 am
by swift1223
I received my new universals from SAV yesterday. The ones with greasable zerks. There is a significant difference in quality between the two types. If you ever have to change universal joints don't waste your money on the ones that are not greasable.
