Changing the hub oil without making a mess
Posted: Thu Oct 02, 2008 1:00 pm
by Squiggas
Has anyone got any tips on how to change the wheel hub oil without it going all over the wheels, tyres, ground etc.?
Posted: Thu Oct 02, 2008 1:27 pm
Two ways, first is obvious, remove the wheels(adjust the brakes at the same time), or take a gallon coolant jug and cut the front out. Wedge it between the hub and the wheel, friction will keep it in place :wink:
Posted: Thu Oct 02, 2008 5:02 pm
by Profpinz
In Australia we have 2 litre plastic Ice-cream containers/tubs that are a perfect size to "clip" in place between the housing and the wheel rim.
The cast strengthening ribs on the bottom of the housing grip the lip of the container while the container sits in place of the inside of the rib.
I'm sure SDP was involved in the design of this container as it couldn't be a better fit if you tried! :wink:
If you haven't got a similar size container available I'm sure you could cut or trim a slightly larger one down to fit
I usually tuck 6 containers in place, crack all the drain plugs, then go and have a cuppa while I'm waiting for the oil to drain!
Posted: Thu Oct 02, 2008 7:00 pm
by pinzinator
Peter, could you post a picture of this container? I'm sure one could be fabricated from a milk jug or laundry bottle. Show it in place on the Pinzgauer, too, if possible.
Posted: Thu Oct 02, 2008 9:30 pm
I've used a long, narrow plastic funnel (think I got mine at an auto parts store) that has the wide end cut on a angle; this fits nicely between the hub and the wheel (with the wheel left on) and funnels the oil inward into a oil catch basin. Hardly a drop was missed.
Posted: Fri Oct 03, 2008 2:25 am
by Ugo
Profpinz wrote:In Australia we have 2 litre plastic Ice-cream containers/tubs that are a perfect size to "clip" in place between the housing and the wheel rim
Peter,
Guess ice-cream has a horrible taste when you re-use those containers after changing hub oil!!
Just kidding ... :wink:
Ugo
710k & 716k in Torino, Italy
Posted: Fri Oct 03, 2008 3:39 am
by Profpinz
Ugo:
Pinzgauer hub-oil flavoured icecream ..... could be lovely!
After all, anything "Pinzgauer" has to have something going for it! :D :twisted: :roll: :D
Pinzinator:
I'II endeavour to get you a pic at the weekend!
Posted: Fri Oct 03, 2008 12:40 pm
by M Wehrman
A drain pan and an old license plate folded into a shallow V works for me! 8)
Posted: Fri Oct 03, 2008 2:36 pm
by hrafn
M Wehrman wrote: A drain pan and an old license plate folded into a shallow V works for me!
I just use a folded piece of cardboard and throw it away when the job is completed.
Posted: Sun Oct 05, 2008 12:10 am
by PinzEOD
I bought this handy dandy drain pan at NAPA and it fits right in there real nice. No muss, no fuss.
Posted: Sun Oct 05, 2008 6:29 am
by wwcommando
Since the casinos don't use coin anymore, I broght home an old plastic coin can made to hold $100 worth of nickels, it fits perfectly under the plug and even stays in place while the oil is draining, you might be able to talk your bank out of one next time you are there.
