Brake question
Posted: Wed Jul 15, 2009 11:50 am
Would a leak in the hose from the intake manifold to the brake booster have any effect on the travel of the brake pedal? Or could the plastic valve in that hose be a problem?
We've bled the brakes 3 times and on first brake application the pedal still sinks way down but then is fine after that. Braking is okay but the pedal travel is a problem.
Hopefully it's not rebuild time for the master cylinder :(
Posted: Wed Jul 15, 2009 12:04 pm
Try adjusting the shoes, they are not self adjusting :wink:
Posted: Wed Jul 15, 2009 12:21 pm
by David Dunn
Brake adjustment would be the first thing to check... if it still require pumping, check all the rubber hoses for swelling or ballooning, and lastly a bad check valve in the Master cylinder. Other symptems will tell other faults.
But SH ! Don't tell anyone... I didn't say a thing :wink:
Posted: Wed Jul 15, 2009 1:02 pm
by ABSOLUTSECURITY
[quote=
But SH ! Don't tell anyone... I didn't say a thing :wink:[/quote]
LOL!!!!!!!!!!!! :shock: :D :shock:
G
Posted: Wed Jul 15, 2009 1:13 pm
by sdibaja
pcolette: to answer your question, yes. But the effect would be a loss of assist in applying pressure... if there are no leaks in the vacuum hoses then you could/should feel the pedal go down more easily.
Jim and David are steering you in the right path
Posted: Thu Jul 16, 2009 6:58 am
Thanks guys. I completely forgot about adjusting the brakes :oops:
Dang it's hell getting old - too much to remember! I should have learned less :D
