turn signal issue
Posted: Wed Dec 02, 2009 5:27 pm
by yaknowthatguy
hey guys -
I'm still pretty new to the pinz, and don't have as much time to play with it as I'd like (mostly due to work). So please forgive my n00b nature!
my turn signals aren't working. as in, no response to using the turn signal on the column. no clicking, no lights, no nothing inside or out. Same in both directions.
I'm suspicious that it may be a relay - but if anyone else has hints on what to look for, I'd really appreciate it.
Thanks!
Posted: Wed Dec 02, 2009 6:38 pm
First check for power on both sides of breaker#12 with key on and test 4 ways for operation.
Next check that tan wire from t sig switch is grounded to body fwd of dash and rt of relay panel.
Next check for power on green wire at flasher with key on.
If you have power at the green wire, select rt or lf turn signal with switch and then touch green wire to blak wire with yellow or green stripe at flasher. If selected side lights up the flasher is bad, Bussman 263-3 or equivelent.
Posted: Wed Dec 02, 2009 6:53 pm
Ya,
In case you haven't found it already, there's a great parts cross reference site for this sort of stuff:
http://www.sdp-pinzgauer.org/html/parts_reference.html
From my experience, everything works.
Posted: Wed Dec 02, 2009 11:20 pm
by yaknowthatguy
you guys are the best! And Jim, once again you prove why you are THE MAN. I get home from work in about ten days, and can have a go at it then.
thanks a bunch!
