Backup light
Posted: Fri May 21, 2010 6:02 pm
by Byron
I found that it was hard to see backing up at night. My solution was to add a 24v pull knob on the dash to switch a small flood I had mounted under the rear of the pinz. The flood was just a cheap flood light that used H3 bulbs. Works like a champ. The only issue now is I usually get half way down the road before I realize itis still on. I have it wired in so that it only works when the key is on the on position. Does anyone have better ideas on this?
back up light
Posted: Fri May 21, 2010 6:07 pm
Other than memory the only better idea is a illuminated switch, not too expensive and better than blinding those behind you.
I mounted a toggle switch above 4 wheel lever below the wiper motor, if its to the left the light is on. That is also where I mounted the two switches for the front flood lights for desert night driving. Each switch is for one light.
Posted: Fri May 21, 2010 6:29 pm
by Byron
I mounted the control knob and power switch to my remote Go Light I have mounted on the roof there. Dang I need a bigger dash for switches. lol
Posted: Sat May 22, 2010 6:12 am
Many of us have installed switches on the transmission which engage when reverse is selected. From memory, there is a plug above the drive-shaft output which is removed and replaced with a momentary-on switch, such as this one from S.A.V.
http://www.pinzgauer.com/showdetails.ph ... 161850320/
Wire it inline with your backup lamp and you're all set. No other knobs on your dashboard, and no forgetting that it's on.
more options
Posted: Sat May 22, 2010 5:06 pm
by Kaweeka
also available from the forum sponsor with instructions . . .
http://www.expedition-imports.com/produ ... gauer.html
http://www.expedition-imports.com/categ ... h_install/
Then again if someone were tailgating you it would be fun to have a "back up" light you could just turn on :twisted:
Posted: Mon May 24, 2010 6:18 am
Thanks Kaweeka.
I didn't mean to ignore Scott out at E.I. You can certainly get one from S.A.V., but E.I. is a sponsor here, and that's a good thing.
Posted: Mon May 24, 2010 6:29 am
by Pinzgauer Pete
This is a nice easy and painless installation, and never realized before buy SAV is NOT a sponsor of this site...hence...my business goes to Scott! :D
