Universal joints - is there after market or just originals
Posted: Sun Aug 01, 2010 9:07 pm
by Jerbearyukon
I need two for the draive shaft off the tranny.
jer Bear
Posted: Sun Aug 01, 2010 10:06 pm
by 4x4Pinz
have seen three different styles of ujoints. Some are easily replaceable with either stock or aftermarket. Which ever direction you decide to go the drive shaft should be balanced once the new ones are installed. I take all my drive shafts to a local company and have them replace the ujoints, inspect and rebalance the shaft.
U-Joints
Posted: Sun Aug 01, 2010 10:19 pm
by Thomas-E
A good idea, let a shop check it out.
If you are running at high speeds a lot it would be worth balancing!
I read somewhere that there is a aftermarket U-joint.
Original
Pinz #710.2.22.626.0
Aftermarket
BONDIOLI & PAVESI , part #41205
Driveline service of Fresno 800-824-0706
DNE41205 Kit
Posted: Sun Aug 01, 2010 10:24 pm
by Jerbearyukon
thanks...not sure where to take them here put I will see.
Jer
Re: U-Joints
Posted: Mon Aug 02, 2010 2:42 am
by spandit
I think you're on the wrong forum...
Posted: Mon Aug 02, 2010 4:06 pm
by Jerbearyukon
Hi speeds...ok your kidding right...the fastest I have ever driven her is 118 KMS per hour and that was down a steep long hill in neutral...tee hee.
Anyway i talked with Karl from Pinzgauer Canada and he said just make sure I have the spline lined up right (so I have to mark it before I replace them and she will be ok....so I ordered them from him.
Now I have an Exhaust leak....unbelievable. Should be BRAND NEW SOON....hahahahahaha
Jer Bear
u-joints
Posted: Mon Aug 02, 2010 9:39 pm
by pinzdriver
swiss army vehicles have after market ones i use them all the time and it is a good idea to have the shaft balanced like mike said.
