Page 1 of 6
EFI
Posted: Sat Aug 21, 2010 11:45 am
by HafWit
Has anybody taken the plunge and done an EFI conversion? If so, did you use the parts from a Volvo 164 or go a different route? Details would be appreciated.
Greg
Posted: Sat Aug 21, 2010 12:47 pm
by M Wehrman
The previous owner of my TGB had a CIS system installed from an early 80's volvo. After a lot of parts replacing,(injectors,thermo-time switch,warm up reg and cold start injector) it runs pretty good. The only issue that causes irritation is a CIS system does not use a fuel rail as on EFI,therefore starting after hot shut down,I experience a form of vapor lock at the injectors. This system was not designed to be in the hot environment of the Volvo. A lot of time was spent on this and the start issue is the real bugger. If I go back again,I will look at converting to an EFI system from a later 80's straight 6 eng,ford comes to mind...
Mark
Posted: Sat Aug 21, 2010 9:29 pm
by rollingpinz
Hello
I would look into aftermarket or consider adaptation. I talked to the local volvo shop and he said that some of the vital components were getting hard to find. The comparable engines with the fuel injection are the B30E in europe (higher compression like the existing engine) and the B30F in US (lower compression, so no need for premium, but less output). Another shop said that there were some physical diferences in the heads such that a direct swap of the goods onto the carb head is not easily done. The best approach would be to swap from the head up. Best of luck.
Pringle
Posted: Sat Aug 21, 2010 10:03 pm
by HafWit
Thanks Mark & Eric. I know that many of these modifications have been done (especially in Europe), but I would like to get some further opinions before I formulate a plan. The carbs have been causing problems and so EFI is looking more attractive.
Greg
Posted: Sun Aug 22, 2010 1:08 pm
by M Wehrman
Greg,I'm sending Jim a care package,maybe that will help.
Mark
Posted: Tue Aug 24, 2010 5:34 am
by geckoadventure
I have been looking at microsquirt and using a jeep 4.0 manifold.
Posted: Thu Aug 26, 2010 3:20 am
by Jim LaGuardia
Greg sent me an interesting link.
http://www.pattonmachine.com
They make a throttle body conversion using the existing carbs.
Posted: Sat Oct 02, 2010 12:09 am
by Jim LaGuardia
As soon as the kit arrives, I will be posting up some C303 EFI installation pic's
The kit can use stock distributor with pertonix module or 123 distributor(preffered method).
Posted: Sat Oct 02, 2010 9:58 am
by wrangler_tj
I'am very interested in the process.
I follow this topic.
My friend has a c303 with efi from factory.
Posted: Sat Oct 02, 2010 10:33 am
by HafWit
I can't wait! If it is done in time, I may go to Mogfest. I might also trailer the Haflinger there.
Greg
Posted: Mon Oct 11, 2010 11:49 am
by M Wehrman
Well? Did you get the stuff?
Mark
Posted: Mon Oct 11, 2010 2:54 pm
by Jim LaGuardia
Should have the kit in the next few days.
Follow the link to
http://www.Pattonmachine.com
Better yet, you can come out to see it all go together if you want
Posted: Tue Oct 12, 2010 9:48 am
by HafWit
If it weren't for that Columbus guy, you'd probably already have it.
Greg
Posted: Tue Oct 12, 2010 3:26 pm
by M Wehrman
+++Better yet, you can come out to see it all go together if you want
_________________
I would love to,but perhaps some pics would be more economical!
Mark
Posted: Wed Oct 20, 2010 2:55 am
by Jim LaGuardia
Ok, Here are some pic's as I work through the PattonMachine injection kit installation on Greg's Mobile Fortress.
I am currently building the mounting panel for the ECU, Power supply and relays.
