TD master cylinder question
Anything DIESEL driveline, axle, suspension related goes here.
Anyone know if the P80-P93 Brake master cylinder(28mm) is used in any Mercedes sedans? Looking for a cross ref so I can locate a rebuild kit or replacement in So Ca. Need part :roll: s to get the old Croatia truck back up and running.
wrangler0511
Post by wrangler0511 »
Are you sure that the brake master is from a TD?
I had a different Diameter in mind so I took the old Brake master apart
that came out of my 716M P80. The old piston has about 29mm
Diameter. I will measure them properly tomorrow.
Have you got a Picture of the Brake master. It might be easier
to Identify it.
Richard
wrangler0511
Ok its definitively a TD master cylinder. Sorry about my doubt
about it.
The problem is that I don't know of any Mercedes that uses a
28mm master cylinder.
The only thing I can do is tell you the Part number of the repair kit.
The Manufacturer is FTE and the Number is RK28506.
But please double check if it is the right number.
One thing I can do is to find a repair kit in Austria and
send it to you.
Richard
Thanks for the kit number, I will check with my brake reliner/supplier and see if he can source it here :D
fesm_ndt
Post by fesm_ndt »
one on Ebay, but looks different http://cgi.ebay.co.uk/Pinzgauer-Master- ... 48365fcdfd
I have one in the container, if urgent I can dig it out and photograph it?
Regards
(Project Gimpy 2)
wrangler0511
The one on ebay is definitively not a brake master cylinder.
I believe that it is a clutch master.
Richard
fesm_ndt
Post by fesm_ndt »
yeah definately don't look correct. I was looking at the description that it is a brake one but as you said it dont look right.
odd I have over a 1000 piccies but none of the master cylinder :roll: I know the clutch is from a merc 123
I would guess the brake master would be LT, just waiting on my LT parts manual to arrive
Regards
(Project Gimpy 2)
wrangler0511
Actually I rebuild a VW LT right now. It has a Master with about 23mm Diameter.
There's countless versions though. So I might be mistaken.
Actually Jim's Pictures are the right ones. It is a TD Master.
Richard
fesm_ndt
Post by fesm_ndt »
:D I just digging through the Girling site now as curious what their numbers are for future reference
Regards
(Project Gimpy 2)
fesm_ndt
Post by fesm_ndt »
No luck with the Girling website
I got a Merc and VW parts disc, as its got me curious now what it may come off.
Regards
(Project Gimpy 2)
yaknowthatguy
Post by yaknowthatguy »
anybody had any luck with a cross reference on the TD master cylinder? Be great to have options for an MB part.....
712 amb. under construction.
fesm_ndt
Post by fesm_ndt »
I just sent an email with some comments from the TD site
Regards
(Project Gimpy 2)
HOOPS PINZ
Post by HOOPS PINZ »
The master cylinder on e bay was a clutch master cylinder. I bought it for my Pinz
As soon as I looked at it I knew what it was so did OK on it with the price
fesm_ndt
Post by fesm_ndt »
Good buy that. Hasn't been much on ebay of much interest lately
Regards
(Project Gimpy 2)
