Fiat wheels on a Haflinger
Posted: Sun Oct 03, 2010 11:59 am
Here's how I went about replacing the skinny stock Haflinger wheels and tires with wider Fiat wheels with Michelins. Fiat is the only company I know of that shares the 4 X 98 bolt pattern and has nice wheels, but unfortunately uses 12 MM lugs. The Haflinger uses 10 MM.
First, find a set of Fiat wheels on Craigslist, these were in Seattle. Search for X/19 wheels.
Get the wheels sandblasted.
Powder coat with RAL 6014. I did this at home.
Have lug nuts made. There is no lug nut available in a 10 X 1.5 that will fit the Fiat wheel, no one makes them. The stock acorn nuts will not work safely, regardless of what you might hear from 'experts'. I made an AutoCAD drawing of this lug nut, contact me off line if you would like a copy in .PDF.
Get some good tires. Off road tires aren't made in 13", so I settled for all-weather Michelins. I can always mount the stock wheels and tires any time I want to.
Ready to go! I can't say how they ride, as I have an inner tie rod removed and won't have a replacement until tomorrow.
Overall view. Not much I can add to this photo.
Here's a spare set of wheels I also found on Craigslist, in case I ever get bored with the current set. I will powder coat these the color of the body.
