Slow signal light flasher
Posted: Tue Dec 07, 2010 1:33 am
by Malahki
Just got my new Pinz 710m home and I am going through everything getting it ready for the dreaded "out of province vehicle inspection". One thing that has got me wondering is how slow the signal lights flash. Light stays on for probably 2 seconds and then goes out for just a split second. Is this normal?
Posted: Tue Dec 07, 2010 1:38 am
If all the bulbs are good, replace the flasher, it is worn out.
Posted: Tue Dec 07, 2010 1:51 am
by Malahki
I also found that my rear hazards are not working and found on another thread it could be a worn flasher. Does one flasher control the signal lights as well as hazard lights?
Posted: Wed Dec 08, 2010 2:00 pm
by Smiley
My turn signals would work sometimes, and then not at all blinking at random intervals if any. I put in a new electronic flasher and all of a sudden everything worked. The lights on the dash worked, all turn signals worked and even the hazards worked, including that little light in the switch for the hazards to indicate they are on. Best $17 I could have spent.
Smiley
Posted: Thu Dec 09, 2010 6:07 am
by stiffler4444
seems my signals work, but the dash lights are intermitent.....guess my problem is probably wiring.....
Re: Slow signal light flasher
Posted: Sat Apr 25, 2015 12:04 pm
by boeing7873
My problem with the dash lights resided in burnt connectors on the diode/resistance unit under the dash. Not sure what the name of the unit is. on the schematic it has a 65 and 66.
Posted: Sat Apr 25, 2015 2:27 pm
Jerome,
It's cool that you resurrected an old thread, and updated it with your experience too. It always helps others in the future if the symptoms and fixes are found together, instead of in a bunch of threads. FWIW, were your symptoms the same as the original poster's?
