Back door rattle
Posted: Sat Dec 25, 2010 6:05 am
by Pols497
My back door on my 712 M has a rattle when I run it down bumpy roads. It looks like the hinges have some wear on them. Has anyone come up with a fix on this other than replacing the hinges?
Posted: Sat Dec 25, 2010 10:34 am
I replaced all the weatherstripping and that snugged it up somewhat. 3M makes one for automotive trunks, etc. that works well and is less expensive than the original.
back door rattle
Posted: Sat Dec 25, 2010 11:56 am
by Pols497
Does it look like the original rubber trim? Where did you get it? Thanks for the reply.
Posted: Sat Dec 25, 2010 1:43 pm
No, it doesn't look like the original - it's a hollow round style. I think this was it:
http://www3.3m.com/catalog/us/en001/hom ... utput_html
It also comes in a different size, I think part #08651, 11/16" x 1/2". If I can find my old package I'll see what size I used.
It does not provide quite as good a seal as the original, although I suppose this will vary from Pinz to Pinz. I seem to remember it was less than a third of the original which runs about $40/meter.
I got it at the local Farm & Fleet but I think any auto supply should be able to get it.
DOOR RATTLE
Posted: Sat Dec 25, 2010 4:42 pm
by Pols497
that looks like it would work better than the original, thanks, I'll see if my local NAPA store can get it for me.
Posted: Sat Dec 25, 2010 5:05 pm
08650 is the part number of the one I used.
NAPA carries it:
http://www.napaonline.com/Search/Result ... &Nty=1&N=0
back door rattle
Posted: Sun Dec 26, 2010 7:15 am
by Pols497
thanks pcolette
quick cheap fix
Posted: Sun Dec 26, 2010 7:07 pm
by michaelh712
My back door rattled a little, even after replacing the rear door weatherstripping.
Another quick and cheap fix:
Slip a rubber hose washer on the male catch on the door and the rattle disappears. Cheapest fix on a Pinze!
Posted: Sun Dec 26, 2010 7:28 pm
michaelh712,
Thanks! I'm going to do that tomorrow.
Re: quick cheap fix
Posted: Sun Dec 26, 2010 8:32 pm
michaelh712 wrote:My back door rattled a little, even after replacing the rear door weatherstripping.
This works well if your latch mechanism is loose enough (too loose?), however if you are unable to open the door after the addition of the hose washer, have someone else repeatedly shove on the door (from the outside) while you work the release handle after a shove or two it should release. Your door latch may not be loose enough to need a full hose washer. Don’t ask how I know about this… :roll:
Ed
Posted: Tue Dec 28, 2010 8:11 pm
by chacaocop1
I had the same issue. The hose washer should work. I solved my problem like that.
