Battery Relay Replacement?
Posted: Thu Jan 27, 2011 10:45 pm
by Smiley
I was looking to replace the original battery relay on my rig. Would any 24v high amp 4 prong relay work. I know they have OEM replacements but they are like $86. I found a 24v 40 amp relay for $4. Am I missing anything here? Thanks for any help.
Smiley
Posted: Fri Jan 28, 2011 4:49 am
by spandit
I'll stick my neck on the line and say yes, it will work. It's only a relay. The originals have a mounting bracket built in, which you'll have to get round but as long as it's well sealed you should be fine. You could even relocate it somewhere more accessible, I suppose!
Posted: Fri Jan 28, 2011 10:42 am
by Smiley
Hi Robin,
Thanks for taking the time to answer. I will go ahead and order the cheaper relay and see how it works. I will plan to relocate it to and have it in an easy to reach and also check location. Will post back when I get it completed and let everyone know how it went.
Smiley
Posted: Sat Jan 29, 2011 6:03 am
by spandit
Need to change my relay too as it happens. According to http://www.sdp-pinzgauer.org/html/bypass_relay.html it's only a 20A one so yours will be more than adequate. In fact, I'm wondering whether with headlights on, Eberspächer running etc. the original one is powerful enough?
