techniques for loosening that big giant cooling fan nut
Posted: Sat Mar 05, 2011 4:14 pm
by indigoth
so, my fan belt is pretty loose. I really should adjust it before it leaps off the pulley somewhere. that big nut is mondo tight. I had a 4 foot breaker bar on it and couldn't budge it. I had some trouble holding the pin wrench in place while i was fighting with it. I don't have an impact wrench, nor am I able to get one in the near future.
any tips/clever ideas?
Jim
Re: techniques for loosening that big giant cooling fan nut
Posted: Sat Mar 05, 2011 4:33 pm
Mine was also mondo tight...took two of us. One to hold the stock pin wrench (while on the driver side) I had to stand on it, and the other
to turn the nut with a breaker bar. My friend had a very interesting tool that went on the square end of the bar and multiplied
the force. I have not seen one before or since, been looking though.
Posted: Sat Mar 05, 2011 5:07 pm
I think this might be what you're looking for:
http://www.northerntool.com/shop/tools/ ... _200315001
I saw one used once and was very impressed but couldn't convince myself I'd use it often enough. Of course that hasn't stopped me before when buying tools
Posted: Mon Mar 07, 2011 6:29 am
by spandit
I've discovered that normal driving does the job. I hope none of the cars behind us on the M6 got hit by the bits
Waiting for a tow truck
Posted: Mon Mar 07, 2011 9:34 am
Robin,
Did your fan blow up? I'm assuming so, from your reference to "bits". Pretty dramatic when it happens.
I found a piece embedded in, and nearly through, my engine cover. I ended up pulling the top tin off the motor, and found parts jammed into the cooling fins.
I can't help remembering the incident every time I run an engine with the cover removed.
A blast shield would be a wise idea for such an application.
Posted: Mon Mar 07, 2011 9:53 am
by spandit
No, fan is OK. It's the nut, pulley half & spacers I've lost. Writing this from the passenger seat if an AA flatbed
