4wd and locker LIGHTS ?
Posted: Sun Jun 05, 2011 9:14 pm
by norcal pinz
my lockers and 4wd is engaging but the lights on the dash don't come on like their supposed to :
I checked for power at the lights and its there ,when i give it ground they come on
what should i check next ??????????? thanks......
Re: 4wd and locker LIGHTS ?
Posted: Sun Jun 05, 2011 10:46 pm
by pcolette
Look for the switch cover (03-25-02) that is opposite each of the hydraulic locker slave cylinders. The diagram of Group 03-25 shows them fairly clearly. Coming out of each cover is the wire from the switch with a spade connector to the wiring harness. These connectors often get corroded and filled with dirt. A good cleaning/scrapping often solves the problem you're having. The connectors are not the easiest to get at so someone with small hands might help.
Posted: Sun Jun 05, 2011 11:47 pm
by norcal pinz
i cleaned all the connectors already its not that, but thanks.
Any other ideas anybody ?
Posted: Mon Jun 06, 2011 1:56 am
by pcolette
It's not likely all 3 switches are bad so how about the connector that all 3 grounds run thru? Any chance that's not fully seated?
Posted: Mon Jun 06, 2011 3:57 am
by Jim LaGuardia
Look for dirty ground connection at switch covers. All the switch does is provide the ground circuit for the lights , double check the 3 wire connector(ground each terminal to test), there is one more connector with the 3 locker circuits under the dash . If you ground each wire at the switch cover and all 3 lights come on, then your switches are most likely dirty or the floating actuating pins are missing.
Posted: Mon Jun 06, 2011 12:55 pm
by norcal pinz
im in the middle of it now it appears that the wires inside the switch cover are old and weren't making a good ground, so im going to replace all the short wires inside the covers with new connectors. thanks Jim and folks !
Posted: Mon Jun 06, 2011 2:53 pm
by norcal pinz
i got both locker lights to work but not the 4wd light but now i know how everything works so it shouldn't be too hard to fix that one.
