broken dizzy cap
Posted: Fri Sep 09, 2011 12:59 pm
Thought it would be a good idea to replace the dizzy cap while adjusting the valves as the old one had a bit of build up on the contacts.
While tightening down the new one I heard a bit of a grinding sound, similar to the sound of sand between two surfaces. Seems the tab in the
cap had not been ground down quite enough and the pressure of tightening it caused it to crack. I gave it no real notice and went on with my work.
Ah, the perils of being a novice quasi mechanic.
I had adjusted the valves and the no 3 cylinder still had a bit of a tapping noise so I removed the cover and checked it again which required me to
remove the cap to check the position of the rotor...good thing as that is when I found the new broken cap. No 3 had one valve misadjusted which
was the cause of the tapping. I think I may have used the .30mm gauge and not the .20mm
If I had not rechecked the valve I would have not noticed the cap being broken. Hate to think where that would have left me sitting. I put the old cap
on and am in the process of ordering a new cap for a spare.
