can you jumpstart a pinz with another pinz ?
Posted: Tue Mar 06, 2012 2:17 pm
by norcal pinz
Hi guys my K battery went dead can i jump start it with another pinzgauer in normal fashion i already know not to jump start it with a regular 12 V system
thanks Guys !
Re: can you jumpstart a pinz with another pinz ?
Posted: Tue Mar 06, 2012 2:21 pm
by Jim LaGuardia
Yes, 24v+ to 24v+, 24v- to 24v-
Posted: Tue Mar 06, 2012 2:24 pm
by norcal pinz
so no disconnecting of wires ? just pos+ to pos+ neg- to neg-
and im assuming a normal set of jumper cables will work ??
Posted: Tue Mar 06, 2012 2:27 pm
by David Dunn
There are also threads on this forum on how to jump a 24v ( dual battery) system from a 12v system... it just takes safety precautions, but not difficult
Posted: Tue Mar 06, 2012 2:29 pm
by norcal pinz
Thank you Guys !!!! i always like to double check here before i fry something .
Posted: Tue Mar 06, 2012 7:02 pm
by edzz
norcal pinz wrote: and im assuming a normal set of jumper cables will work ??
Yes
Posted: Thu Mar 08, 2012 3:07 am
by spandit
I keep a laminated copy of the 12V jumping instructions in the vehicle - had to use it in anger on more than one occasion!
I suppose being 24V means that jumping from a 24V vehicle means that the leads you use can be thinner (or rather, there is more safety margin)?
Posted: Thu Mar 08, 2012 11:10 am
by edzz
spandit wrote:I suppose being 24V means that jumping from a 24V vehicle means that the leads you use can be thinner (or rather, there is more safety margin)?
Not really. Two group 27's in series = same amp's as one, just twice the voltage, the amp draw determins the wire guage not the voltage.
Posted: Thu Mar 08, 2012 11:58 am
True, but the Pinz electrical system does not pull twice the power of a "normal" 12V vehicle; it is equivalent. So the starter current would be half of what you might expect from a 12V vehicle. This is one reason why the 24V system is considered better; you can realistically draw the batteries down further and still get a Pinz to start because the draw on the batteries is less.
BUT, jumpering a discharged 24V set of batteries will pull MORE current through the cables then could happen with a 12V battery. Remember that 24 volts has twice the energy! Treat it with respect.
Posted: Thu Mar 08, 2012 12:04 pm
by norcal pinz
Turns out i didn't even need to jump start the "K" afterall, there was just enough battery left i shot some starter fluid down the breather hose and she started right up.
