Washer Fluid Pump
Posted: Wed Apr 04, 2012 12:32 pm
by berger
When I got my truck the pump worked, but took quite a few pumps to get fluid. Now it doesn't seem to work no matter how hard I much I pump. What generally fails on these pumps? I haven't had a chance to dive in yet.
Re: Washer Fluid Pump
Posted: Wed Apr 04, 2012 1:55 pm
by stiffler4444
I'll piggy back this thread, mine stopped working last year and I've not bothered to look into it........lazy lazy lazy me....... :lol:
Posted: Wed Apr 04, 2012 3:39 pm
I've found that often the rubber bulb dries out, cracks and leaks air so it can no longer create a suction. Same goes for the plastic lines.
Posted: Wed Apr 04, 2012 8:49 pm
by Winter Beater
I used a generic NAPA 12V washer pump, added a momentary on button and now drive in style :)
Posted: Wed Apr 04, 2012 9:21 pm
by berger
pcolette wrote:I've found that often the rubber bulb dries out, cracks and leaks air so it can no longer create a suction. Same goes for the plastic lines.
Thanks. I will take a look at the lines first, as I am sure they are easier to replace.
Posted: Wed Apr 04, 2012 9:22 pm
by berger
Winter Beater wrote:I used a generic NAPA 12V washer pump, added a momentary on button and now drive in style :)
Did you tap a 12v source?
Posted: Fri Apr 06, 2012 8:43 pm
by Winter Beater
yes. I have a 12V system installed for accessories.
Posted: Sat Apr 07, 2012 6:13 am
by CentAr712
You could also check fleabay for 24v ones; sometimes you can find one pretty cheap. I decided to go electric for reliability, the rubber bulb may be simpler, but I think if it was an electric pump it would still be working. The one I found online happens to be off a CAT road grader, I just haven't had time to install it yet. I plan to mount a momentary push-button switch in the hole where the bulb used to be.
Posted: Sun Apr 08, 2012 8:31 am
by Stekay
I got a SHURflo model #100-030-20. 24volts 1.0 GPM
Posted: Sun Apr 08, 2012 10:41 am
by berger
Posted: Sun Apr 08, 2012 11:57 am
[quote="berger"]Here is a 24v pump for $19.99.
Thanks for the tip! :D I just ordered one to replace my tired manual system.
Posted: Wed Apr 11, 2012 6:27 am
by berger
pcolette wrote:
berger wrote:Here is a 24v pump for $19.99.
Cool! Please let me know how it works for you!
Posted: Sun Jan 20, 2013 9:03 pm
by mopar
Well my pump had a broken nipple. So I attempted a repair will se how it goes.
Posted: Sun Jan 20, 2013 9:22 pm
mopar wrote:Well my pump had a broken nipple. So I attempted a repair will se how it goes.
I’ve had mine tweaked a few times :oops: however thankfully never broken, :shock: sounds painful, let us know if the surgery restores functionality.
Posted: Sun Jan 20, 2013 10:00 pm
Looks to be a fine repair job. How did you do it? Drill and insert the brass looking piece?
