C304 Electric fan swap
Posted: Sun Jul 01, 2012 11:01 am
with the 105 degree days we're having in colorado, the mechanical fan was having a real hard time keeping up at idle.
Installed a flex-a-lite 15" variable speed 24v fan. The fan shroud was 2" too wide to fit in the radiator tunnel, so we trimmed it up on the mill, and used the gasket material that came with the fan to provide a nice seal.
The temperature probe that comes with the kit is supposed to pass through the radiator cores, however the volvo radiator has offset fins, so it will not go all the way through. we sealed it in place with a high temperature sensor safe epoxy.
Results: Fan has no trouble keeping the engine cool at idle now. An added bonus, it is also much much quieter in the cab.
We used the Flex-A-lite Part# 18024 fan, available here: http://www.flex-a-lite.com/auto/html/24-volt.html
As I said, it did require trimming an inch off each side of the shroud. We did it with a milling machine, however you should be able to do it carefully with a dremmel or other such tool. make sure to pull off the gasket before you start and save the material, we reinstalled it by measuring how much we needed per side and cutting to fit (the strip comes as one long continous piece). You will want to slightly relocate some of the electric cabling in the radiator tunnel behind the air intake tube, and the fit will be very tight. The fan kit comes with a series of brackets (2 large blocks and 4 long fins) to mount the fan, there is a sideways crossmember just below where the fan sits that is perfect to mount one of the 2 blocks, and then use a fin to mount to the angled sheet where the differential control panel sits against.
Now to get some air conditioning into the 304... holy god is it hot lately.
