Bad earth connections Pinz 710 M
Posted: Fri Aug 24, 2012 1:07 pm
by firemat
Hi All, I have a bit of an elec problem that I think is a bad earth. When I put the headlights on pos 2 I cannot get the indicators to work, and in pos 1 when I turn on the indicators the dashboard lights flash on and off in time with them. I also don't have any main beam (brights) but I am not sure where the switch to operate them is, does it do on the floor with the windshield washer? I think that must be missing. can anyone point out where are good places to check for the earth points are and how I can remedy the problem? Cheers, Firemat
Re: Bad earth connections Pinz 710 M
Posted: Fri Aug 24, 2012 2:53 pm
main beam (brights) --pull up on turn signal lever
Posted: Fri Aug 24, 2012 2:59 pm
by firemat
Ed, the brights don't work. The relay clicks when I pull the stalk, but the lights don't go on
Posted: Fri Aug 24, 2012 4:38 pm
Posted: Fri Aug 24, 2012 6:34 pm
firemat,
IIRC, the ground is a brown wire, and it bolts to the chassis near the blinker module below the left side of the dash. Perhaps the schiz from edzz will confirm this for you.
Posted: Sat Aug 25, 2012 6:27 am
by firemat
undysworld wrote:firemat,
Thanks, there is one floating around without a home there..........
