710M Rear Canvas Top Install
Posted: Sat May 18, 2013 7:41 am
by khansmith
Hi Guys:
My 710M never came with a top so I have never seen how the front canvas and rear canvas tops are installed. Specifically, I can't figure how the front canvas and the rear canvas connect behind the driver (elephant ears). I have a tuff river stuff front and rear canvas. If anyone has pictures that detail the installation specifics regarding how the installation works, I would be very very very grateful.
Thank You!
Khan
Re: 710M Rear Canvas Top Install
Posted: Sat May 18, 2013 7:48 am
Khan,
Rear top goes on first. The ears flap over the front edges of the rear top, then the rubber rope holds things on under tension. The front top goes on last, and rubber ropes attach to the sides of the rear top.
I've only dealt with one Tough River top, and it has some slightly different hook arrangement than the originals. But that's the basics. Hope it helps some.
Posted: Sat May 18, 2013 9:52 am
by westernair
If you have never had a top you will need the d rings that have sheet metal tails on them to run the black rubber cord through so you can keep the front and rear sections together. Look at SAV they are about $6 each.
Also do you have the aluminum stays that holds the front roof on? The d rings are installed under the front top on the screws that hold the stays on.
I just installed a tough river top myself a few months ago.
