How the heck...
Posted: Fri May 31, 2013 11:58 am
Do your remove this bracket for the front skid plate?
The center bolt is simple but then there are 2 bolts behind the threads of the rubber bushings.
The bracket is so small and tight that I see no way to remove the rubber bushings.
Chicken and egg sort of thing.
Pulling my hair out about this one as wrench will not even fit on bushing bolts as there is no space.
My next step is to rip up whats left of my rubber bushings and then try to cut or drill them out to get to bolts behind!
Re: How the heck...
Posted: Fri May 31, 2013 3:30 pm
by rustywheel2004
Hi Dan,
You must unbolt the rubber anti-vibration mounts from the bracket then the nuts on the center tube flange can be accessed. It's a tight fit for the wrench but it's doable. I have Snap-On Tools wrenches that have heads which are smaller than most manufacturers so this made the process a bit easier.
Steve
Re: How the heck...
Posted: Fri May 31, 2013 6:58 pm
Was at one shop today looking for smaller head wrenches
Did not find anything but will check with some friends and see
It is a crazy tight fit (I have less than 1/8 of an inch to move and that is 'if' I get the wrench to grab!
Will post a victory post if I get the rubber mounts off
Thanks Steve
Re: How the heck...
Posted: Fri May 31, 2013 7:24 pm
by berger
You need a Ural tool kit!!
The ural wrenches have really flat heads that I use on things that a standard box wrench won't reach.
You might try Princess Auto. Tool won't break the bank and many options.
Sent from my Mobile
Re: How the heck...
Posted: Fri May 31, 2013 10:26 pm
by sixbennetts
Go buy a cheap wrench at Wally-World and grind it flat. Shouldn't take more than 10 minutes with a new grinding pad.
Re: How the heck...
Posted: Sat Jun 01, 2013 2:01 am
by spandit
I haven't got a skid plate on mine...
Re: How the heck...
Posted: Sat Jun 01, 2013 10:17 am
by rustywheel2004
Hey Robin,
You might want to get yourself a front skid pan as they are principally responsible for structural support to the front footwell section. Without the pan the front section will eventually sag due to the minimally supported weight of the tub, steering box and driver..
Steve
Re: How the heck...
Posted: Sat Jun 01, 2013 11:18 am
spandit wrote:I haven't got a skid plate on mine...
I did not know you had a Haflinger!
Ok I have 3 plans of attack:
1. 18mm offset box head
2. 18mm angled box head
3. Cheap 18mm I can grind down if 1 and 2 don't work
Will report this afternoon
Re: How the heck...
Posted: Sat Jun 01, 2013 12:07 pm
by spandit
Ah, that clears things up then!
Re: How the heck...
Posted: Sat Jun 01, 2013 3:37 pm
Victory (but it was 17mm
Issue was also that someone put new ones on and the threads were so tall they hit the center tube so could not get box wrench 'over'
Re: How the heck...
Posted: Sun Jun 02, 2013 7:00 pm
by cascade.king
My friend had a vehicle with bolts set like that. The previous owner tightened them on, then cut the handle off the wrench. Coated in greese and dirt, looked ok...
Nice fork, er, wrench.
