Page 1 of 2
rub rail nuts
Posted: Tue Jun 04, 2013 8:20 pm
by norcal pinz
can someone tell me how to install these ? can i use old ones i pulled off another truck ? thanksImage
Re: rub rail nuts
Posted: Tue Jun 04, 2013 8:39 pm
Best not to use old ones as they are pressure fit and won't work a second time
http://www.youtube.com/watch?v=KeaMsvai ... ata_player
Re: rub rail nuts
Posted: Tue Jun 04, 2013 8:48 pm
by sixbennetts
Or, if you're a cheap bastige like me, you'd file a slot across both ends for a big screwdriver.
Re: rub rail nuts
Posted: Tue Jun 04, 2013 9:56 pm
by edzz
Sorry I guess I spent too many years building jets, how the &%^ would cutting a slot in a rivnut do a thing for you.
back on topic viewtopic.php?f=17&t=5138&p=50960&hilit=rivnut#p50960
for more info use the search "rivnut"
Re: rub rail nuts
Posted: Tue Jun 04, 2013 11:10 pm
by pcolette
The rivet nuts are not reusable but are available from McMaster: http://www.mcmaster.com/#standard-rivet-nuts/=n1zczl
There are a few different tools for installing them and McMaster also carries them but they are available other places for less money. I found a pliers-type on Amazon a few years back.
Re: rub rail nuts
Posted: Wed Jun 05, 2013 4:05 am
by Profpinz
:D :P :D ....I've always known them as "Nutserts"
Re: rub rail nuts
Posted: Wed Jun 05, 2013 6:59 am
by berger
Another option are well-nuts. I used these when installing my aluminum rail. Sure, they aren't flush, but with wood you can counter sink them....and they won't rust! They are used on Jeeps for Lizard Skin all the time.
Re: rub rail nuts
Posted: Wed Jun 05, 2013 10:45 am
by norcal pinz
thanks for all the help guys :) those well nuts look cool if i cant find the originals i will use those. does anyone want to rent me thier tool for installing these and i only need one of those nut-serts all the rest are in great shape
Re: rub rail nuts
Posted: Wed Jun 05, 2013 10:56 am
by norcal pinz
TechMOGogy wrote:Best not to use old ones as they are pressure fit and won't work a second time
great video everything i ever wanted to know about rivnuts and More thanks
Re: rub rail nuts
Posted: Wed Jun 05, 2013 12:41 pm
by djw
The following bits I used to replace rivnuts on my 710K (Austrian), and they pretty much match up to the hardware size previously installed.
I don't think the original rivnuts are stainless steel (looks to be aluminum to me), but I put stainless steel hardware to replace the originals.
McMaster Carr:
97467A666 18-8 Stainless Steel Heavy-Duty Rivet Nut, M6 X 1.00 Internal Thread (9mm OD)
93475A270 18-8 Stainless Steel Flat Washer, Metric DIN 125 M8 Screw Size, 16MM OD
92000A438 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M6 Size, 30MM Length, 1MM Pitch
Rivet Nut Tool (6mm) about $18
The tool works great to set rivnuts, less than 1 minute per rivnut. Small enough to fit even a trail kit, does other size rivnuts too.
viewtopic.php?p=50950#p50950
Re: rub rail nuts
Posted: Wed Jun 05, 2013 1:12 pm
by berger
One word of caution, and why I went with the larger well-nuts, if the old hole is misshapen, the rivnuts won't work well.
Re: rub rail nuts
Posted: Wed Jun 05, 2013 3:45 pm
by norcal pinz
i might try the rubber one because i only need 1 the rest are fine thanks everybody
Re: rub rail nuts
Posted: Wed Jun 05, 2013 5:54 pm
by berger
If you do use rubber, counter sink the wood about an 1/8".
Sent from my Mobile
Re: rub rail nuts
Posted: Wed Jun 05, 2013 9:22 pm
by edzz
berger wrote:If you do use rubber, counter sink the wood about an 1/8".
Sent from my Mobile
Assume, counter sink the back side of the wood?
Re: rub rail nuts
Posted: Thu Jun 06, 2013 6:36 am
by berger
Sent from my Mobile
Ya, to accommodate the head of the well-nut.... if you want the wood to be flush with the side. My rails sit out about an 1/8, which I don't mind at all because water won't collect back there.
Picture helps. You can see the well-nut near the end of the rail.
