Replacing Springs
westernair
Replacing Springs
Post by westernair »
OK so I just got a bunch of parts for my hafi shipped to me from overseas. In that order I apparently ordered a set of suspension springs on accident (don't ask) anyway, I am now wondering if after 50 years it might not be a bad idea to change them out. Can someone tell me how I determine if mine are still good or are shot?
Thanks in advance
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Re: Replacing Springs
Length of front spring 8,97636"
Length of rear spring the same
See last page of the repair manual.
As for how to tell without removing - that I don't know.
I removed mine it is pretty simple and if you remove the strap and then droop the axle the spring basically falls right out.
EDIT:
Was thinking after I posted that you would know the length as you have new springs :)
westernair
I just thought there was a way to determine when they were on. I am doing most of my breaks this weekend so I may pull one and look or just shelf them until I do shocks some day.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Garrycol
Post by Garrycol »
westernair wrote:OK so I just got a bunch of parts for my hafi shipped to me from overseas. In that order I apparently ordered a set of suspension springs on accident
My Haffie has heavy duty springs in the rear (from when it was a gold prospecting vehicle in the desert) and as a result the rear wheels point in substantially at the bottom and I only have a couple of inches of rubber touching the ground. As I have to get some new standard springs can I ask where you got yours and what sort of price.
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
westernair
They were $75 each and they came from John Hamilton in the UK.
I am willing to sell mine at cost if someone is interested.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Heinkeljb
Post by Heinkeljb »
Two ordinary coil spring compressors from your local car accessory shop will allow you to compress the spring(s) enough to remove them without having to take the check straps off.
Obviously, if you take the check straps off, you don't need the spring compressors as the drive shafts will drop far enough for you just to lift the springs off the holding pins on the bottom, after the top drops out of the top locating hole.
John
No spring compressor needed on any Haflinger suspension spring 8)
Just pull the lower shock/strap bolt out and lift the body to unload the suspension, springs practically fall out :shock:
Rear springs are slightly thicker than the fronts, .59055" vs. .55118".
