Combat Crockpot
Posted: Sun Sep 08, 2013 9:26 pm
by Stephen91475
Hi guys, I'm new to the pinzy scene and this is my first post to any forum (this forum has been an invaluable source of information). Just ordered one of these to put in my 710m, and was wondering if anyone else has seen/used one. Seems like it would be great for coffee, hot chocolate, heating meals, or even hot water for washing/showers (when hot water is added to cool water). The low setting is supposed to reach 155 degrees, and the high is 185. I hope the pinz can handle the 400 watts.
http://www.ebay.com/itm/NEW-471012-24V- ... 257ff1d209
http://www.isotherm.ca/heater-water-rations-hwr.html
http://www.liberatedmanuals.com/TM-10-7 ... -and-P.pdf
Thoughts?
Re: Combat Crockpot
Posted: Sun Sep 08, 2013 9:32 pm
by berger
I don't know if the Pinz can run it, but that is cool!
Sent from my Mobile
Re: Combat Crockpot
Posted: Mon Sep 09, 2013 10:55 am
by compunerdy
That is pretty cool.. I think I will get one as well. Thanks for the info!!
Re: Combat Crockpot
Posted: Mon Sep 09, 2013 11:31 am
I made my shower from a stainless steel garden sprayer that I can put on the camp stove to heat up. That's cause I could not
find anything like you have gotten. :D
Re: Combat Crockpot
Posted: Tue Sep 10, 2013 9:48 pm
by milesdzyn
I had one but decided to not use it in my build. I didn't want to sacrifice the room it would take up for just heating water, opted for heating water over a stove or by solar means. It is a great product and will run off the Pinz 24v system and is bullet proof in construction. If you have the space I say use it and enjoy hot water.
Miles
Re: Combat Crockpot
Posted: Wed Sep 11, 2013 7:59 am
2 words - Sous Vide
It will do a lot more than just heat water!
Re: Combat Crockpot
Posted: Mon Sep 23, 2013 3:41 pm
by compunerdy
This has a 3 prong connector.. anyone know the mating plug for it?
Re: Combat Crockpot
Posted: Mon Sep 23, 2013 4:21 pm
There are lots of three prong connectors. A pic is helpful if you want to know what might work.
Re: Combat Crockpot
Posted: Mon Sep 23, 2013 4:51 pm
It's an Amphenol plug, http://www.newark.com/jsp/search/produc ... %7Cplid%7C
Here's a link to a thread on Steel Soldiers about this heater: http://www.steelsoldiers.com/showthread ... hlight=hwr
It says:
Pin A: Positive (+) (Violet wire)
Pin B: Negative (-) (Orange wire)
Pin C: No Connection (Yellow wire)
Newark Electronics is where you want to get your connector. The part number you need is
MS3106A16-10S
The cable clamp is the second component you'll need. That part number is
97-3057-1008
Re: Combat Crockpot
Posted: Mon Sep 23, 2013 9:48 pm
by compunerdy
Thanks!!!
Re: Combat Crockpot
Posted: Fri Oct 04, 2013 1:07 am
by DougLennox
Found this site here in Aus that may offer an alternative. Both 12 volt and 24 volt options.
http://www.travelbuddy.net.au
Re: Combat Crockpot
Posted: Fri Oct 04, 2013 10:48 am
by compunerdy
Not sure about alternative.. more like great addition to..
