You know you're not using your Pinz enough when....
Posted: Thu May 15, 2014 3:58 pm
by bonefish635
Birds start nesting in the wheelarches.
Re: You know you're not using your Pinz enough when....
Posted: Thu May 15, 2014 4:03 pm
by undysworld
At least what's in there is still green!
Posted: Thu May 15, 2014 7:20 pm
by EmbarkChief
Take'em for a ride they won't forget.
Posted: Fri May 16, 2014 9:45 am
by Andre
...you stop auto correcting the steering wheel when hard braking your "other" vehicles.
Posted: Sat May 17, 2014 9:57 am
by eToothpaste
...you think there is something wrong when you can only go 45 uphill on the interstate.
Posted: Sat May 17, 2014 2:02 pm
by Andre
... when you start to wonder why no one has asked you if your car floats.
Posted: Sat May 17, 2014 4:48 pm
You wonder why it won't start when you turn the key to the right.
You can't figure out how to get in because you can't find a remote fob for the Pinz.
You drive around all day at 35mph because you forgot you left it in low range the last time you had it out.
Posted: Sun May 18, 2014 12:56 am
by totaljoint
-you leave the head lights on when you park because they don't go off automatically,
-keep looking in the middle of the windshield for the rear view mirror.
-can't remember if sliding the heater and fresh air levers up or down is open or close.
-wonder which way to flip the air control lever under the dash: for feet or defrost, only to be reminded it doesn't matter.
Posted: Sun May 18, 2014 8:15 am
by undysworld
totaljoint wrote:-you -wonder which way to flip the air control lever under the dash: for feet or defrost, only to be reminded it doesn't matter.
Now, that's funny.
Posted: Sun May 18, 2014 12:51 pm
by edzz
Wonder what's wrong when when you leave the hi low box in neutral. :P
Posted: Sun May 18, 2014 12:58 pm
I thought of that, too, but IIRC it happened to someone here so it might be a sore spot :oops: :?
Posted: Sun May 18, 2014 3:10 pm
by David Dunn
… wonder who stole the left pedal?
…wonder why the key won’t turn to the right and why it won’t start, when it does?
… forget to let the truck do a ECU/ABS system check before starting..
…wondering why is it so much harder to turn from a stop than my last Pinz?
…wondering why does it slow to 60mph going up a hill?
…wonder why the 4wd indicator is lit and the switch is off?
… why the group has no sympathy for my Pinz problems? :lol: :P
Posted: Sun May 18, 2014 4:00 pm
by McCall Pinz
You forget where the real 1st gear is...
and you can't get through the intersection when you do try to use it.
Posted: Sun May 18, 2014 6:51 pm
by edzz
And he’ll likely give me a hard time about the brain farts that prevent me from getting my Ural into first gear after having backed in to a space when I parked it. :lol:
