C303 Electric fan conversion
Posted: Mon Sep 21, 2015 8:35 pm
by dokatd
Re: C303 Electric fan conversion
Posted: Sun Oct 25, 2015 12:34 am
by dokatd
Just a quick follow up now that I have my fuel injection completed.
The Volvo fan works perfectly. It really only needs the low speed setting, I still have it wired to come on full time at the moment but will be changing over to a PWM fan controller soon. The truck barely breaks 170*F right now and I really need it to warm up a bit more for the fuel injection to really work efficiently. Changing to an electric fan is a huge upgrade for the C303 and I can't recommend it more highly.
Posted: Sun Oct 25, 2015 1:18 am
by ako
Looks like a very neat shroud you have made. No where for that air to go but through the radiator.
Posted: Sun Mar 06, 2016 9:54 am
by ranicotra
Very neat work. Are you running 12v from a converter to run the fan ?
Posted: Thu Apr 07, 2016 8:11 am
by dokatd
Sorry for the late response, yes I am running a converter. But you can run the Volvo fan on the low speed with 24V indefinitely. However that is a lot of cooling power and you will find it hard to stay warm.
Posted: Mon Jul 04, 2016 8:35 am
by Klug
I guess it means the GM ECM can not control the fan?
Posted: Mon Jul 04, 2016 12:32 pm
by dokatd
Klug wrote:I guess it means the GM ECM can not control the fan?
No, the GM computer does not control the fan. However there are some work arounds that will let you do it with the GM computer but it's not ideal. I am using a Derale PWM fan controller now. The electric fan runs very rarely at more than 50% unless you are really pushing the trucks limits and it over 90*F. At idle in 95*F the fan barely comes on.
Posted: Tue Jul 05, 2016 5:57 am
by Klug
Never heard of the Derale PWM controller, not sure I can find it in Europe 8-/
Do you have any picture of the way you setup the coolant probe (T on the hose?)?
Posted: Sun Aug 07, 2016 6:11 pm
by dokatd
Below is the Temp log from my EFI computer. This log was started at about 5pm sunday 8-7-16. The route took me from my house out to the George Bush Tollway here in North Dallas. The majority of hte run was on the tollway to work the truck above 60mph. Max speed was 72MPH on GPS (over-sized tires helped speed but hurt temps). The max temp is 220.5*F which is where it stabilized. Temps were being taken from the deepest darkest hole in the coolant system which will be showing about the hottest point in the coolant system. Im no engineer but I would say a single fan setup in Pull configuration with a proper shroud works just fine for the majority of the C303 population. Quite frankly I don't care to drive this truck in these high ambient temps anyways so I take my motorcycle or air conditioned Unimog. Ultimately however I do plan on adding a decent sized oil cooler to take the edge off when I find that I am forced to drive this truck at these temps especially once I get around to putting in my higher speed gears sitting on my desk.
SENSOR:Coolant Temp
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
99.6
100.4
100.4
100.4
100.4
100.4
100.4
100.4
100.4
100.4
100.4
100.4
101.3
101.3
101.3
101.3
101.3
101.3
101.3
101.3
101.3
102.1
102.1
102.1
102.1
102.1
103
103
103
103
103
103.9
103.9
103.9
103.9
103.9
104.7
104.7
104.7
104.7
104.7
105.6
105.6
105.6
105.6
106.5
106.5
106.5
106.5
106.5
107.3
107.3
107.3
108.2
108.2
109.1
109.1
109.1
109.1
110
110
110
110
110
110.9
110.9
110.9
111.8
111.8
112.7
112.7
112.7
113.6
113.6
114.5
114.5
115.4
115.4
115.4
116.3
116.3
117.2
117.2
117.2
118.1
118.1
119
119
119
120
120
120.9
120.9
121.8
121.8
122.7
122.7
123.6
123.6
123.6
124.5
124.5
124.5
125.4
125.4
125.4
126.3
126.3
126.3
127.2
127.2
127.2
128
128
128
128
128.9
128.9
128.9
129.8
129.8
129.8
130.7
130.7
130.7
130.7
131.6
131.6
131.6
132.4
132.4
132.4
133.3
133.3
133.3
133.3
134.2
134.2
134.2
134.2
135
135
135
135.9
135.9
135.9
136.7
136.7
136.7
137.6
137.6
137.6
138.4
138.4
138.4
139.2
139.2
140
140
140
140.9
140.9
140.9
141.7
141.7
141.7
142.5
142.5
143.3
143.3
143.3
144.1
144.1
144.8
144.8
144.8
145.6
145.6
146.4
146.4
146.4
147.2
147.2
147.2
147.9
147.9
147.9
147.9
148.7
148.7
148.7
149.4
149.4
149.4
150.2
150.2
150.9
150.9
150.9
151.6
151.6
152.4
152.4
152.4
153.1
153.1
153.1
153.8
153.8
154.5
154.5
154.5
155.3
155.3
156
156
156
156.7
156.7
157.4
157.4
157.4
158.1
158.1
158.1
158.8
158.8
158.8
159.5
159.5
159.5
159.5
159.5
159.5
159.5
160.2
160.2
160.2
160.2
160.2
160.2
160.2
160.2
160.2
160.2
160.2
161
161
161
161
161
161.7
161.7
161.7
161.7
162.4
162.4
162.4
162.4
162.4
163.1
163.1
163.1
163.1
163.1
163.1
163.9
163.9
163.9
163.9
163.9
163.9
164.6
164.6
164.6
164.6
165.3
165.3
165.3
165.3
165.3
165.3
166.1
166.1
166.1
166.1
166.8
166.8
166.8
166.8
167.6
167.6
167.6
167.6
167.6
168.4
168.4
168.4
168.4
168.4
169.2
169.2
169.2
169.2
169.2
170
170
170
170
170
170
170
170.8
170.8
170.8
170.8
170.8
171.6
171.6
171.6
171.6
171.6
171.6
172.5
172.5
172.5
172.5
173.4
173.4
173.4
173.4
173.4
173.4
174.3
174.3
174.3
174.3
174.3
174.3
175.2
175.2
175.2
175.2
175.2
175.2
176.1
176.1
176.1
176.1
176.1
177.1
177.1
177.1
177.1
177.1
177.1
177.1
178.1
178.1
178.1
178.1
178.1
179.1
179.1
179.1
179.1
179.1
179.1
179.1
180.2
180.2
180.2
180.2
180.2
181.3
181.3
181.3
181.3
181.3
181.3
182.4
182.4
182.4
182.4
182.4
183.5
183.5
183.5
183.5
183.5
183.5
183.5
184.7
184.7
184.7
184.7
184.7
184.7
184.7
184.7
186
186
186
186
186
186
187.3
187.3
187.3
187.3
187.3
187.3
187.3
188.6
188.6
188.6
188.6
188.6
188.6
190
190
190
190
190
190
190
191.4
191.4
191.4
191.4
191.4
191.4
191.4
191.4
191.4
191.4
191.4
192.8
192.8
192.8
192.8
192.8
192.8
192.8
192.8
192.8
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
194.4
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
196
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
197.6
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
199.3
201.1
201.1
201.1
201.1
201.1
201.1
201.1
201.1
201.1
201.1
201.1
201.1
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
202.9
204.8
204.8
204.8
204.8
204.8
204.8
204.8
204.8
204.8
204.8
204.8
204.8
206.8
206.8
206.8
206.8
206.8
206.8
206.8
206.8
206.8
206.8
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
211
211
211
211
211
211
211
211
211
211
211
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
220.5
218
218
220.5
218
218
220.5
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
218
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
215.6
213.3
215.6
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
213.3
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
211
208.9
211
211
211
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
211
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
208.9
Posted: Mon Aug 08, 2016 8:56 am
by ranicotra
Where did you get your high speed gears from ?
Posted: Mon Aug 08, 2016 3:34 pm
by dokatd
ranicotra wrote:Where did you get your high speed gears from ?
Place called "The House of the Flying Spanners"
Posted: Fri Jan 11, 2019 1:55 pm
by Lee6x6
Can you provide more details of your EFI setup. Did you come up with this?..
Posted: Fri Jan 11, 2019 3:03 pm
by dokatd
I am using a Patton fuel injection system. I will be selling it soon once my engine swap is complete.
Posted: Sat Jan 12, 2019 8:26 am
by Lee6x6
Thanks for your reply. Where are you in Dallas? I am in colleyville (by grapevine, south lake). I have a C304 that I bought last June. Glad to hear another C owner near by. Be great to meet and talk shop some time. I am interested in the EFI set up you have as well.
Posted: Sat Jan 12, 2019 8:31 am
by dokatd
I’m in far north Dallas. George bush and north tollway. Pm me and I will send you my email and number.
