Great job...
I have chose to mount the injectors for my set up in a different location, much closer to the cylinder head to reduce the effects iof fuel falling from suspension at lower RPM. My injectors are installed into the manifold and there is no fuel rail needed with the weld in adaptors that we have made to allow this.
I have now went through 5 different sizes of plenum and 4 different T/B sizes, the results have been very odd compared to what I have witnessed with other engines I have manipulated with EFI. Its my belief that this is due to the Pinz camshaft particulars with its very tight lobe center lines...
Jim, that looks like a 55 or 60mm T/B- what is it?? Do you know how much volume your plenum has? It will be nice to see some comparisons when I get my system dialed in and fully developed.
Then it's time to start all over again for the 3.3L beast
