Engine Assembly Question
Locked
hrafn
Post by hrafn »
When fitting the cylinders to the crankcase, the service manual says to
"Smear cylinder pad with sealing material." I presume the "pad" is the
base of the cylinder, but what sealing material is appropriate, bubble gum,
silicone rubber, etc... ? I suppose that you wouldn't want to use a sealant
that got hard or actual glued the cylinder to the block.
On another topic, I have found that a product called Marine Clean, from the
POR-15 folks, works great to soften and remove carbon deposits on the
pistons and head.
Jay
W3PNZ
710K Kommandowagen
M Wehrman
Post by M Wehrman »
I use the hardening Permatex on the cyl bases. It seems the closest to the original hard stuff. I've used it on 3 engines with no problems. It also offers a long set-up time for minor repositioning.
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Post by Jim LaGuardia »
The proper sealant is permatex aviation sealer #2. Apply it to the sealing surfaces. Take care not to get it on the piston skirts . I do the block mating surface and 1/4" into the mounting holes as well as the cylinder mating surfaces.. This sealer is used on almost every component on the truck.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
hrafn
Post by hrafn »
Thanks gents,
Good information and great pics.
Jay
W3PNZ
710K Kommandowagen
Locked
