New tires
I've had the 285 Dunlops mudders on my 712 with stock rims for nearly 3 years and love them. 17000+ miles and I've just recently 'flipped' them. I anticipate another 17000 at least. I keep the road pressure at 50 (per Mike Nims suggestion) and air down to about 20 for off-roading.2012 wrote:pittspinz - are your new dunlops on stock rims?
anyone - do 285's fit on a 712?
BTW...danger pay? I always found demo pay to be more...rewarding.
Mike Newton 1973 712M (sold)
yes!!! i was told a 712 wont take as big of a tire as a 710 will, but a 285 is just fine. thx for the data.
i'm tossed up between bfg, these dunlops, and swampers. actually, a swamper fell apart on me on the freeway so i'm not that stoked on them anymore. i need a tire that's awsome in ALL circumstances. i will seek out this miracle. and yeah, i'll probably end up settling for "close" again.
I should add that I did have a problem one time when I was a younger, less experienced pinzer. I managed to bounce the rear enough on a foolish obstacle that I stuffed one rear tire against the top of the wheel well. No tire damage, but it did sorta kinda twist the outer axle housing about 270 degrees. It was NOT pretty. Nice thing about a 712 tho, I chained up that axle, pinched the brake line with a vice grips and drove her home 90 miles on 5 wheels.
dennis - so the 305 designation indicates the ratio (and therefore width) as well as the height? i get the idea from your post that that the traction problem is created by the increased width of the 305's - ultimately the extra contact area. again, i'm fully from funtion junction (a wonderful place where the population find beauty in performance ALONE), so decorative tires disinterest me. what tires would you suggest for a daily driver/very offroady 712 with stock rims?
here's some decoration i just don't get:
My next Pinz mod... not sure quite yet. I'm currently working with a company that makes aircraft canopies to come up with a polysomething hardtop for the rear and front of the Pinz. Then, get with someone to make the soft sides and rear pannels - attached via an awning channel. But that should be another post to see what kind of interest it kicks up.
John
John
Johnjgeesen wrote: Then, get with someone to make the soft sides and rear pannels - attached via an awning channel. John
I have really enjoyed the hard top rear for the flexability it provides. I put a luggage rack from a mini van on the hardtop which allows me to install all the aftermarket items normally used on the roofs. I currently am running my yakima basket but have wanted to see what the Pinz would look like with my Packasport carrier. I used the A-rail to attach my soft sides so that I could remove the canvas and either run without it or put on a "canopy in a bag". I do like the soft top front as we like to run with the door tops off and the canvas rolled back most of the time.
They are ready for loading on a train or ferry with height limitations. Notice the other autos sitting in queue.
Probably on the way to Africa or another remote place for a few weeks of fun.
This same technique is quite effective when loading tall vehicles into shipping containers.
-Sean
