Start button starting to go?
Or is it the starter solenoid? Once in a while when I go to start up my truck, the starter button does nothing when pushed. After repeatedly pushing it over and over, it will "catch" and power the starter motor. I've already tried jiggling the wire connectors under the dash, so it's not a loose connection. Any ideas??
Haven't really looked that close at one, but couldn't you just open it up and clean the contacts inside. After all it is just a momentary contact switch that gets the same build-up of contaminants layer as any other high voltage electrical contact.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
