would anyone know 24V equivalent of the the standard 12V Stop/Turn Bulb used in trailers.
Just because you can do something does not mean you should.
Life is tough! It is even tougher when you are stupid.
John Wayne
John Wayne
24 volt Bulb numbers
Single element 12volt 1156 = 24volt 1683
Double element 12volt 1157 = 24volt 1662
In case your local NAPA can't or won't get them for you, they are available online from www.bulbman.com using the above part numbers.
Paul
Paul
