http://www.aircooledtechnology.com/gall ... /movie.gif
Unless you are like me and willing to change most every internal aspect of the Pinz engine to make it something it was never meant to be, leave it bone stock and I'll guarantee you'll get exactly what the Austrians promised you. (take that from a guy that does nothing except develop engine combinations and components and thoroughly tests them daily)
After almost 4 solid weeks and 40 hours of actual engine test time the lab portion of the Pinzgauer EFI system is completed. Over this period of time we gathered dozens of comparative plots from a bone stock carbureted engine as well as 3 different injector positions and two different intake plenum designs.
So... What have we learned?? Well it took us over 3 solid weeks to attain even ONE dyno graph that superseded the overall engine output that we recorded with the bone stock carbureted Pinzgauer engine- Even using modern technology and a team of engine specialists that are wel versed with manipulating aircooled engines.
During these tests we learned that simple changes that typically make huge power increases on other aircooled engines simply are not effective means of Pinzgauer engine manipulation, this was not expected and it caused serious challenges during the development. These challenges and the difficulty that we experienced in actually making more TQ and HP during the testing proves just how specific the Pinz engine was developed to work as a given unit, with every part remaining as the factory created it, even an air filter change KILLED the tq and hurt HP as well, just like removing the filter did or swapping mufflers- the Pinz engine is one well oiled machine that operates it's best with stock settings and components.
The EFI kit:
It became very clear on the 3rd day of lab testing that the destiny of the development I have been working on for two years off and on would be in question. This is because I require many things to be present with any development that gets my pedigree and these things were not evident with the first tests. I consulted with my staff and decided to go forward with our testing outline even though it may prove to be a total waste of lab time, thats because I had individuals commited to the kits and I owed these people and the development my time to try every conceivable combination with before throwing in the towel.
Some notable portions of the testing:
The first 3 weeks were filled with tests using existing EFI plenums and other injector locations with them. None of these tests were found to be anywhere close to the stock power, even when tested with different exhaust and air filters as well as timing manipulation.
The first injector position was down low in the manifolds, this position offered fair torque but a limited RPM range that was worse then the carbs. This is the most dangerous location for the injectors as they are inside the fanshroud and they also disrupt cooling air within the fan shroud and tins, on top of that they are the most difficult to install and service later requiring disassembly to get to any fuel hoses or injectors. here is the pic of the low injector position
The second location was up top, in the plenum. The plenum used for this is the same unit used on the Red Bull trucks, made by the same person and using the same throttle body.
This position proved to be horrible as we lost both torque and HP and the engine definately usd more fuel and achieved higher temperatures faster than with carbs or the lower injector position. The most notable portion of this position was the HUGE flat spot in acceleration that was absolutely unable to be removed despite accel trim, raised fuel pressure or manipulated timing. It was apparent that the Red Bull plenum had inherent design problems because our exhaust gas temps raised on cylinders 2&3 and dropped on cylinders 1&4 from all the other tests, indicating mixture quality issues on the outboard cylinders- Not even carburetors had this much EGT variance before I tuned them!
The results of these tests were so disappointing that I was ready to pull the engine off the dyno and give up- But I have never done that before and certainly wasn't going to now!
After testing this plenum and injector position I can now see why the Red Bull trucks have issues, I can solve those with a Plenum swap because it worked for us!
RAT plenum design one V2:
I don't believe in sharp corners inside plenums, so I never favored the Red Bull plenum, I also didn't fancy it's volume as it was certainly too small and the injectors spraying into the plenum was certainly making for some improperly mixed intake charges.
My way of curing this was to place the injector at the parting line of the intake runner and intake manifold, just below the plenum. At this point my hypothesis was this position would stabilize EGT through better mixture quality of having the injector in the port and it would also make the injector much easier to service and inspect for leaks/etc. This location was by far the most strategically placed for fitting into the truck as well.
We added plenum volume and treated this portion of the development like the Pinz engines was one of our typical aircooled engines. We increased the displacement of the plenum to 2.2L which is 88% of the engine's total displacement (typically 90% is the desired plenum/displacement ratio) in hopes that this would leave enough plenum charge to make the engine run smoother, idle better and through both of these we'd make more power everywhere and increase down low, just off idle torque.
The result was a first dyno run that was better than all the other EFI tests to that point, but still did NOT beat the stock carbureted engine. What we did note was cooler running and MUCH, MUCH SMOOTHER running with even a few mechanical sounds removed that had been present the entire time. We worked to smoth out the fuel numbers in the ECU because now the engine wanted a bit leaner charge, indicating much more efficiency than it had with the upper injector location and the power started to come up and the engine began to scream! In the controls I could feel the difference and the trained ear could tell that the engine was pulling much faster thrugh the RPM range. The engine's smoothness is partially attributed to better, more stable air flow within the plenum as well as absolutely stable fuel delivery and pressure created by our "Fuel distributor" that was addeed when we swapped to the final plenum.
Later that day we finally broke the power of the bone stock carbureted engine and continued until we made enough power to successfully seperate our power plots from the comparative graphs generated by the computer for the stock engine, but unfortunately we did not pick up the percentage of power that we were looking for, or the amount that I mandated to call this a true accomplishment so I shut the dyno down and went home.
This past Monday I came in the lab with an understanding that the results from that day's optimizing would determine the future of the kit and after 27 back to back dyno runs with altered timing, altered fuel curves and even an updated microprocessor chip install I wasn't able to equal the 88HP I had achieved on Friday, nor was I able to improve upon the torque. I did make the engine run smoother and consume less fuel with some better fuel values in the mid range, but other than that it was another wasted day.
Here are some answers to some FAQ.
- The EFI system has proven to make only minimal HP and torque power differences when in top tune compared to a bone stock carbureted 2.5L engine.
- The EFI arrangement provides a very stable (stock) idle at 800-1,000 RPM
- The fuel smell associated with carburetors is eliminated.
- The engine runs much smoother, engine harmonics and vibrations are greatly reduced. I feel this is a benefit of the latest plenum design and fuel delivery system and it's ability to provide stable fuel pressure to each injector as well as air flow that isn't disrupted due to inefficient plenum design (as noted with the Red Bull plenum).
-dual carburetor synchronization, tuning and associated issues are eliminated.
- Engine temperatures are decreased overall
- A definite reduction in fuel consumption was noted, especially with the latest plenum and injector position.
- Will the system need tuning when received? YES despite outrageous effort we have made to tune the systems beforehand tuning will be required, but on a minimal level.
- Can I expect my Pinz to drive and behave like a 2008 Hummer? NO, programming will still be necessary, but all the hard work is completed.
- Will the system make for altitude compensation? YES, but higher elevations will still need to be tuned initially. After the majority of elevations and manifold pressure values have been tuned further tweeking is not typically necessary.
While this system is the simplest available to tune, install and work with it doesn't posess magical characteristics that will be perfect right out of the box, unless you are located in my back yard where all the tuning and testing has been done.
In summary:
I am disappointed, both as an enthusiast and an engine and component developer. I am not happy at all about the amount of time, effort and money that was invested in this development for a measley 3-4HP gain and only 5 lb/ft of torque over the bone stock craburetors. Sure we made a gain, but is that gain really worth 2500+ bucks and all the time to install the system in the truck and go through the EFI learning curves? As an enthusiast I don't believe so and that further disappoints me.
The original target price for this kit was retail at 2,500.00, unfotunately at the time I made this pricing schedule I had no idea that the very simple plenum would not work well nor did I expect to spend as much time in the lab to get the system optimized, moreover I did not expect to achieve such poor numbers from the engine. In the beginning I told myself that if I couldn't achieve 95 HP/ 140 TQ with EFI that I would not consider the development a success.
My time in the lab is very valuable, with the level of experience, tools and data logging that we have what we have done here over the past month would have cost anyone else 1,000.00 per day (thats my going rate for development work for other companies) so this further disappoints me.
As it stands now I know that we are going to have some disappointed customers, both with the results of the testing and with the fact that I really don't know what to do to complete this project, but rest assured that no one is as disappointed as me, because I am not accustomed to failure and this is the first time it has happened with a development that has so much time and effort invested at my company. Had I been like everyone else and simply made the engine run and attained a partial fuel map boxed it up and sold it none of the things we have noted would have occured, it has been my goal from day one to thoroughly develop and understand any part that leaves my facility. This makes for great components with support to back them up and that is priceless in today's world.
So, the facts are the plenum that actually works is expensive to make, it took me 8 solid hours of welding to complete and the few amount of units that are going to be sold won't be enough to substantiate mass production that could make for more cost effective components.
I'll close by saying that had I been an enthusiast that was just here to observe the tests from start to finish from carbs to EFI, having no vested interest in the outcome that I would not spend the money or take the time to outfit the system and work through the EFI learning curve for the benefits.
Find that bold honesty with any other retailer in today's world. (especially a retailer that developed the system and has thousands of dollars in the testing of 40,000.00+ worth of "pre sold" kits)
I have no doubt you will , and look forward to wheeling with other injected trucks.I will conquer this monster.
These reasons would be plenty enough for me to still be interested in EFI.The EFI system has proven to make only minimal HP and torque power differences when in top tune compared to a bone stock carbureted 2.5L engine.
